RV.Net Open Roads Forum: Technology Corner: Memory leak with Firefox?
 > Memory leak with Firefox?
Ramblin' Ralph
Central California Coast
Posted: 10/22/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I just updated to FF 82.0 yesterday and ran into the same "slow" problem and noticed a couple of FF processes using 2+ gigs. I do keep a lot of tabs open, but never had this problem before.
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 125 watt solar
My RV Travels Webpage / Yearly Campsite Map / 715 Campsites / YouTube Videos /
Instagram / Twitter
1492
Arlington, VA
Posted: 10/22/20 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
No, not really seeing memory leak through memory usage appears higher than previous versions. Firefox is releasing memory, slow in my case. In fact, seeing 603MB with 2-tabs open, one being media heavy. In Chrome, which is also open, I'm currently using 1,500 MB. Though on Adobe Max streaming webinars all day, not really surprising? BTW, Adobe Max is free this year, which ends today. Many of the workshop sessions will still be available on-demand. Helpful expert tips if you are using Adobe CC apps.
Are you using any Firefox add-on/extensions which can be a source of memory leaks? You can try restarting in 'Help > Restart with Add-ons Disabled'. And check if memory leaks still exists?
Also, modern websites rely heavily on media and scripting, and poorly written scripts in particular, can result in browser memory leaks.
CFerguson
on the road
Posted: 10/22/20 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
gemsworld wrote:
I have been a faithful Firefox user for many years, mainly because of the add-ons. I finally threw the towel in a few weeks ago and switched to Edge. I could no longer take the constant freezes and lockups caused by Firefox.
Wow, interesting. I've run FF for years but without addons and have never experienced a lockup. fwiw, i usually have 10-12 tabs open at a time.
garry1p
Oklahoma
Posted: 10/22/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
I really wanted to continue using Firefox but memory usage was out of site.
What I did.
click on tools / options / scroll down to performance uncheck hardware acceleration / change processor limit to 2.
cut my memory usage from over 1GB to 400/500 MB no noticeable changes in performance that I could tell.
Let me know if this helps since I discovered this by trial and error would like to know if others have the same results.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
fj12ryder
Platte City, MO
Posted: 10/22/20 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Garry, that really helped a bunch. Thanks for the help, it's still using too much memory, and not releasing as it should, but it is tons better. It no longer crashes after a few hours of usage.
Howard and Peggy
"Don't Panic"
