sssooo
Ohio
Hello
I have a2018 fleetwood bounder on a ford chassis the last time I did the oil ,a few years ago the oil came out on the cross member and ran all over the place and made a mess. Is there a trick to bo this without the mess?
rlw999
Washington State
sssooo wrote: Hello
The best way I've found to deal with that mess is to pay a shop to do it :-) I don't mind the mechanical work of an oil change, but don't want to deal with capturing and disposing the used oil.
When dad ran into a similar problem with his tractor (farm sized tractor, not a lawnmower), he bent some sheet metal into a channel to guide the oil flow into his pan. He used the same trick to help catch the drips from the oil filter too (which always seemed to drip a half quart of oil)
K Charles
Connecticut
Or a 5 qt oil jug cut in half the long way.
IAMICHABOD
Sunny So Cal 90713
I changed out all my drain plugs to a Fumoto Oil drain Plug no more mess.
Just pop on the Hose Kit and put into your drain vessel and turn it on.
Check out the one that fits your motor,some times they come as a kit.
Also Check Their Website to find what you want.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
ppine
Northern Nevada
Fumoto works well.
dodge guy
Bartlett IL
Id be more worried about an oil change every few years more than a mess on the frame.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
w4phj
Vero Beach
IAMICHABOD wrote: I changed out all my drain plugs to a Fumoto Oil drain Plug no more mess.
x2
2005 Bounder 37U Cat C7 Engine
2014 Jeep Grand Cherokee Limited
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
dturm
Lake County, IN
X3
Doug & Sandy
Kaylee (12 year old Terrier of some sort), Sasha 3 yr old Golden
Kaiya at the Rainbow Bridge
2008 Southwind
2009 Honda CRV
Check out blog.rv.net
Bill.Satellite
Full-timer
An oil change every couple of years goes against "my" grain but if removing the drain plug does not allow a clear drop to an oil pan or similar then the Fumoto plug is awesome. My generator has that problem and it was solved with the Fumoto.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
georgelesley
Tennessee
dturm wrote: IAMICHABOD wrote: I changed out all my drain plugs to a Fumoto Oil drain Plug no more mess.
X3
X4
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
