RV.Net Open Roads Forum: Received new vehicle with nail implanted in tire-maybe.
 > Received new vehicle with nail implanted in tire-maybe.
boston blacky
Gatineau Quebec Canada
Posted: 10/21/20 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Picture this. Today my dealership switched the veh. tires to winter tires which go into their storage area until sping 2021. This is a new car less the 2 months old. It came from the GTA (Toronto) area and already had approx.700 km. on it before I took possesion. We live
just outside Ottawa, Canada.
The tire guy noted a nail in one tire and said no plug would work as a good fix. My new car now has only 2888 km. and my position is -about 1/3 of that was there already before I received it. So, was the nail there already and should I just shut up and have that bad tire replaced at my costs. All comments and are welcome.
BB
BOSTON BLK
Monterey, California
Posted: 10/21/20 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Unless your detective skills can prove otherwise, you’ll be buying a new tire IMO.
Old-Biscuit
Verde Valley
Posted: 10/21/20 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
No telling when nail attacked the tire ... could have been on your way to dealer
Have an Internal Patch repair done
Unless nail is in outer/sidewall area...then replace
Didn't NEW tires come with road hazard coverage/warranty??
US NAVY------USS Decatur DDG31
MitchF150
Puyallup, WA
Posted: 10/21/20 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
So, you have never driven said vehicle yet? You bought it, and now they are switching to snow tires and found a nail in one of the summer tires?
time2roll
Posted: 10/21/20 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
New car is defect only through the tire manufacturer only unless you give in to the finance guy trying to upsell along with the rest during purchase. Road hazard is not a defect.
Yes many tire stores give free flat repairs, if repairable, on the tires they sell. Unrepairable tire is still your cost unless again you option for the additional warranty.
Used car is probably sold "as is" with the factory warranty. Same goes for a scratch in the paint you notice later that day after the purchase.
Otherwise you need to negotiate a settlement with the seller.
675w Solar pictures back up
Sjm9911
New Jersey
Posted: 10/21/20 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Swap out the fixed tire with the plug for the spare, assuming you have a full size one. Just happened to me also, nail in the brand new truck tire. Not much you can do.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Mark Heisler
Alberta Canada
Posted: 10/21/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Like Old Biscuit said Just go get the tire fixed properly
Tires are fixed every day.
If in the face fix it
If in sidewall replace it
Things happen.
* This post was edited 10/21/20 06:30pm by an administrator/moderator *
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
dougrainer
Carrolton, Texas
Posted: 10/21/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
USA tires stopped Road Hazard warranty 7/01/1977. How do I know this? I purchased a NEW 1977 Trans am. delivery date--7/07/1977. In August I hit the remnants of a screwdriver on the hiway and blew out the Uniroyal RR tire. Took it to the Pontiac dealer that was also Uniroyal dealer. They came out and showed me the object in the destroyed tire and when I stated it should be under Road Hazard, he showed me the updated memo's from the Tire makers showing the above date they stopped Road Hazard on new tires. That is why Tire retailers sell Road Hazard warranty's. The correct repair if the nail is on the flat side of the tread is to remove the rubber, install a plug and then install a patch on the inside of the tire over the plug. Anywhere else, replace the rubber. Doug
bukhrn
Lanexa, Va
Posted: 10/21/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
This guy that told you that a nail in a tire couldn't be fixed with a plug, is full of it, unless the hole is in the side wall as stated earlier.
He's trying to sell you a tire unnecessarily, he probably sidelines as an RV salesman.
No special effort to plug a nail hole, any 16 year old with a plug kit is capable of plugging a tire.
Also if you have a bolt rather than a nail, it may be another story.
* This post was edited 10/21/20 06:31pm by an administrator/moderator *
2007 Forester 2941DS
2014 Ford Focus
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 10/21/20 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
EGADS this brought back memories of the worst road hazard damage I ever saw. New Fors ½ ton not long from the dealer. Ran over a makeshift skeleton of ½ inch rebar. It tore up three of four tires brake hoses and brake lines, transmission cooler lines, emergency brake cable and transmission shift linkage. In México. I played watch man as he went to find a tow truck.
The new baby buggy 18" to 24" tires. Are repairs the same as on normal tires? Some tires are priced out of this world at Costco. Four hundred dollars?
