RV.Net Open Roads Forum: Class A Motorhomes: Weak headlights
 > Weak headlights
Teleman
Clayton, CA, USA
Posted: 10/21/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 88 Coachmen Classic and I wonder if the is an HID headlamp option for the old sealed headlamp style. Any ideas?
garyemunson
Reno, Nevada
Posted: 10/22/20 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Look for the DOT numbers molded into the lens and google to see what they actually came off of. Work from there. There are brighter bulbs available for most headlight assemblies at Autozone or O'Reilleys.
dodge guy
Bartlett IL
Posted: 10/22/20 05:50am Link  |  Quote  |  Print  |  Notify Moderator
LED is a better option. Do some research to see how each LED is made. Some put the LED right where the filament would be which gives it the same beam. Others put multiple LEDs which throws off the beam and then you just have a bright light with no actual beam. If you have the old square glass halogen/sealed beam bulbs you can buy new housing that take H series bulbs that you can put the LEDs in.
Something like this.
Headlamp option
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
folivier
Southeast Louisiana
Posted: 10/22/20 06:33am Link  |  Quote  |  Print  |  Notify Moderator
First check the voltage at the headlight terminals. It is probably less than what's at the battery. Most vehicles use a too small wire that goes through the headlight switch down to the lights which results in a lower voltage at the lights due to the amp draw from the lights. The best option is to add a relay so the wires from the headlight switch go to the relay that you mount near the lights. Then run a larger gauge wire to that relay then to the light. That will give you a higher voltage and more amps at the light which will give more light.
If that isn't enough then you could change the lights to better ones and will still have higher voltage at the lights.
Do a search for this upgrade.
JRscooby
Indepmo
Posted: 10/22/20 06:35am Link  |  Quote  |  Print  |  Notify Moderator
First step, IMHO, would be check the voltage at the headlamp using the same ground and power path. I have found corroded connections in the wiring (often on ground side) can cause a dim lamp.
BurbMan
Islip, Long Island
Posted: 10/22/20 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Definitely get the HIDs. Go to The Retrofit Source and see if anything fits your headlight type. I made a set of HIDs for my 2002 Grand Prix that were 10000% better than stock. Just make sure they are aimed properly....
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Teleman
Clayton, CA, USA
Posted: 10/22/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses. I will definitely explore these options.
oldave
Tx
Posted: 10/22/20 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
* This post was edited 10/22/20 02:01pm by oldave *
oldave
Tx
Posted: 10/22/20 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Look here for info and parts
http://www.danielsternlighting.com/
Ray
Teleman
Clayton, CA, USA
Posted: 10/22/20 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Found some LED replacement headlamps on Amazon. We'll see how it goes!
 > Weak headlights
