RV.Net Open Roads Forum: Tech Issues: Humming sound in 5th wheel??
 > Humming sound in 5th wheel??
dougrainer
Carrolton, Texas
Posted: 10/22/20 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Xantrex Pro XM1000 is an 'INVERTER' used to inverter DC (from batteries) to AC for that residential fridge
'CONVERTER' used to converter AC from AC Source (shore/gen) to DC for the 12V System and maintaining/charging batteries
You could have BOTH...Inverter and Converter
If you unplug shore power then Converter will stop operating --- Converter Fan
Should stop as it is AC Powered
If you turn off Inverter....then it will stop
Inverter Manual
Determine which one is making the noise.
Humming could be 'Normal' or an indication of component failing
Are you positive about the CONVERTER fan is AC? Some Converter fans will stay running once the 120 is removed if the converter is hot enough for the fan to run. Doug
mrad
Prineton, MN
Posted: 10/22/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
12th Man Fan wrote:
If you are rigged for a generator then I would suspect the ATF(auto transfer switch).
I am rigged for and do have an Onan 5500. I just tried turning both battery switches off and the humming sound was still there.
12th Man Fan
Flower Mound , Texas
Posted: 10/22/20 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Unplug from shore power and see if it stops.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
time2roll
Posted: 10/22/20 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off the breakers one at a time. Main breaker(s) last. Then unplug.
675w Solar pictures back up
