RV.Net Open Roads Forum: Tech Issues: 5th wheel front landing gear motor
 > 5th wheel front landing gear motor
Curly2001
Tucson, Arizona
Posted: 10/22/20 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Had the front compartment open on the fiver the other day and hit the raise side of the front landing gear. The motor moved up and down just a bit and that surprised me to see it move. I am wondering if they all have some give to them on the mounts so they are not rigid. The mounting bolts all seem tight. Just curious.
Thanks,
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
schlep1967
Harrisburg, PA
Posted: 10/22/20 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Mine moves also. I think of it as a shock absorbing system so the gears don't abruptly bash together when changing directions.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Old-Biscuit
Verde Valley
YES there is SLOP in motor/gear box mounting
Normal
US NAVY------USS Decatur DDG31
Curly2001
Tucson, Arizona
Posted: 10/22/20 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much for the reply. I was a little worried that it would jam or something.
Regards,
Curly
bpounds
Sophmore Brain...
Posted: 10/23/20 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Yes as others said, the motors just have an anti-rotation limit, not a hard fixed mount. Makes it all a bit self-aligning with the shaft.
However, keep an eye on it, because that gearmotor is likely just plastic and the OEM version often ends up breaking. That lets the gearmotor over rotate, which at best jams the rotation, and at worst rips wiring loose. I have replaced mine with an all aluminum body gearmotor which is readily available.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
