RV.Net Open Roads Forum: Tow Vehicles: Maximum towing
Search only in Tow Vehicles
 > Maximum towing
mr61impala
Versailles Ky USA
Posted: 10/23/20 04:59am Link  |  Quote  |  Print  |  Notify Moderator
Hello. It's been awhile since I've been here and I had forgotten how much fun this forum can be. Awhile back we decided to buy another travel trailer and we picked out one that weighed #5700 with a tongue weight of just under #800.
We purchased a new half ton Hemi crew cab with every available towing option including 3.92 gears, Ram rates it to tow #11,400 with a bed capacity of almost #1800.
Since we got this truck we started thinking maybe we could tow a little bigger camper and are wondering what would be a comfortable match to this particular vehicle. If you are towing with a 3.92 Hemi truck I would love to hear your story.
I am not into anything approaching it's maximum values as I don't want to hear the engine screaming up every hill, just wondering if #7000 or even #8000 trailer was a reasonable option. I will say when I'm towing my small tractor and bush hog on a #1550 tandem trailer (total weight of about #4500) you can barely tell it's back there.
Thanks in advance for your help.
Shopping for Travel Trailer
pitch
NY
Posted: 10/23/20 06:20am Link  |  Quote  |  Print  |  Notify Moderator
You can tow to ratings. Personally I would not go over #8000 gross. That is just me, for no reason, other than me being a belt and suspender type guy!
That engine "screaming" up hills is doing just what it is designed to do. Hemi makes its power at I think around 3600 rpm,(screaming). If you don't want to listen to an engine running well within its design parameters, sell your truck and buy a diesel!
I have a '13 Ram and it gets my juices flowing when tugging up a hill in third gear, the thing just pullin like a freight train!
valhalla360
No paticular place.
Posted: 10/23/20 06:25am Link  |  Quote  |  Print  |  Notify Moderator
If you are talking about GVWR (not empty weight)...I would say around 7000-7500 is probably going to be the comfortable limit (keep gear in the truck limited).
That will put the hitch weight a bit under 1000lb. Assuming combined weight of passengers of around 500lb, that leaves you around 300lb for running boards, truck cap, etc... plus any gear in the bed.
The "tow rating" is likely not the limiting factor.
* This post was edited 10/23/20 07:13am by valhalla360 *
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
APT
SE Michigan
Posted: 10/23/20 08:38am Link  |  Quote  |  Print  |  Notify Moderator
The general feedback for people towing over 8000 pounds loaded with half tons is not positive. How much is your as equipped payload and receiver rating? 8000 pounds loaded means 1000-1200 pounds of tongue weight. How much stuff/people do you put in the vehicle when towing? That Tire and Loading sticker will likely be your limit well under 11,000 pounds for a TT.
2017 Subaru Outback 3.6R
mr61impala
Versailles Ky USA
Posted: 10/23/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Just the two of us in the truck and we have always packed with weight in mind.
This truck came from the factory with a class 4 hitch which I believe is rated up to #10,000.
The larger trailers under consideration have the following specs:
1). UVW of #7050 and hitch weight of #710,
2), UVW of #6500 and hitch weight of #735.
Posted: 10/23/20 10:14am Link  |  Quote  |  Print  |  Notify Moderator
That drivetrain is bulletproof and will rip the hitch off of most any TT. It’ll have similar power to all the new 3/4 ton gassers.
Only downfall IMO is the relatively compliant rear coil spring suspension which can be overcome with an appropriate wdh and/or a set of airbags.
I’ve hooked some heavier trailers to a rental Ram 1500. (I’m in construction, so “weights “ are relative. If it ain’t on the bump stops it’s good enough).
The rear is a little squishy-er than leaf spring “normal” half tons. Not including the heavy payload F150.
I wouldn’t blink an eye at an 8000lb TT.
near Bishop, California
Posted: 10/23/20 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Any buddies with an 8,000 pound trailer that you could try out? Around the block, up and down a hill.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
goducks10
There
Posted: 10/23/20 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Anything over 6,000 lbs and you'll join the 1/2 ton towing issues crowd.
Rams coil suspension is not a rigid as leafs. If you do go heavy I would invest in some air bags for the rear coils. My son has an older coil sprung Ram 1500 and is loaded to the max and tows a 4,000 lb ski boat. He added bags to the rear and says it really help with stability.
Power wise you're good to 8,000 IMO if you like the sound a V8 wound out in the mountains.
From a BTDT perspective I'd stay at 7,000 lbs or less.
MitchF150
Puyallup, WA
Posted: 10/23/20 11:05am Link  |  Quote  |  Print  |  Notify Moderator
When I shop, I look at the GVWR of the trailer.. Not the UVW, as that's a meaningless number to me... I pack heavy, admit to it and proud of it! [emoticon]
I went from a #5000 GVW TT to a #7000 GVW last year and with my max tow F150 with the Eco, it's about all I want to tow with it and STILL have a comfortable tow... (My F150 is rated for #11,300)
Here are my door stickers to compare to. I know I'm pretty much maxed out, as I said, I pack heavy and load up the bed and the trailer.
Good luck! Mitch
Terryallan
Foothills NC
Posted: 10/23/20 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Good luck! Mitch
Looks like if you load both to max. You are over weight by more than 3000lb
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
 > Maximum towing
