RV.Net Open Roads Forum: Technology Corner: Hulu, or something similar?
 > Hulu, or something similar?
Page of 5
MrWizard
Traveling
Posted: 10/26/20 01:21am Link  |  Quote  |  Print  |  Notify Moderator
"I’m wondering if I can plug it to iPhone?"
If you can find an iPhone connections conversion cable/connector to ethernet/LAN
Maybe, but i DON'T know if that's available
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
austinjenna
Columbus, Ohio
Posted: 10/26/20 05:54am Link  |  Quote  |  Print  |  Notify Moderator
I have Verizon unlimited so get 15gb of hotspot. My wife has the same so total we can get 30gb of just hotspot alone.
Verizon does differentiate between hotspot and phone data.
You can always get a USBx to HDMI cable and plug that it into your tv and start whatever app on your phone and watch it on the tv so this uses no hotspot data just your phone data.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
valhalla360
No paticular place.
Posted: 10/26/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
coolmom42 wrote:
Verizon does not differentiate between phone data use and hotspot data use.
Unless I'm reading the plans wrong, they do. You can get 'unlimited' data but no hotspot. If you want hotspot they will allot you so many gigs, then throttle you.
This is true. After the hotspot allotment, it does throttle but as long as you are using standard def, it still works OK.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
srt20
Wisconsin
Posted: 10/26/20 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Ok here is what you can do without all that screwing around. You have an iPhone, correct?
1.Subscribe to your fav streaming service. We use Youtube TV.
2.Buy a lightening to hdmi adapter. Amazon or Walmart. Spend the $$ to get the actual Apple brand adapter. BTW it will have 2 female ports the HDMI port and a USB port, plus the lightening plug on other end. This is the one you want. You can charge phone while using it to watch TV.
3.Download streaming service app to your phone. Open app find what you want to watch.
4.Plug adapter into phone, you will also need a hdmi cable that goes from adapter to TV. Plug hdmi into TV, make sure the input on tv is the same as the HDMI port you plugged into.
Watch your stuff without using your personal hotspot on your phone. I dont full-time but we do travel alot and I always use this setup to watch my local sports channels for local teams. Buy a 6 ft HDMI cord so you can change the channel on your phone easily.
You used to be able to cast or mirror you phone onto smart tvs but the stream services have pretty much stopped that. But using the cords works better and much quicker anyway.
2oldman
NM
Posted: 10/28/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
srt20 wrote:
2.Buy a lightening to hdmi adapter..
Lightning?
1492
Arlington, VA
Posted: 10/28/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Look at Verizon Visible for $40. month. Unlimited 4G data and hotspot. No set data throttling.
Caveat, it works with a limited number of smartphones.
1492
Arlington, VA
Posted: 10/28/20 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
They do have these adapters for iPad as tablets are popular as kiosk. Should work with iPhone?
2oldman
NM
Posted: 10/28/20 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
1492 wrote:
Look at Verizon Visible for $40. month. Unlimited 4G data and hotspot. No set data throttling.Caveat, it works with a limited number of smartphones.
That's the catch for me. I can't bring my phone, and they make you buy another one.
srt20
Wisconsin
Posted: 10/28/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Lightning?
The plug for an iPhone.
If you have an android then you buy a mini usb to hdmi adapter.
srt20
Wisconsin
Posted: 10/28/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Mobile hotspot capped at 5mbps PLUS it says it may be slower than other traffic....
Page of 5
