RV.Net Open Roads Forum: Tech Issues: Water heater question
 > Water heater question
RJsfishin
Winston Or.
Posted: 10/28/20 11:51am Link  |  Quote  |  Print  |  Notify Moderator
I have never known a drippy PRV to cause any problem
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
dougrainer
Carrolton, Texas
Posted: 10/28/20 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
capacitor wrote:
I spoke too soon. The above solved the igniter issue but the original problem was water dripping from the pressure relief valve. I replaced it and the thermostat also. I put a 130 degree thermostat in and then the igniter issue happened. That is solved but now the relief valve drips and the water temp is 128 but it wont shut down. bad pressure relief valve even tho it is new? Thanks again, i'm stumped.
My old-timer RV tech told me they will do. 2 trailers have done it. only when running.
I am 65. I have been a RV Tech for 41 years. What qualifies as a Old-Timer???? THEY DO NOT DRIP IF THE SYSTEM IS FUNCTIONING CORRECTLY. Doug
Bill.Satellite
Full-timer
Posted: 10/28/20 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^^^^^^^^^What he said!^^^^^^^^^^^^
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
