RV.Net Open Roads Forum: Tow Vehicles: GM's Max Trailering Package
Search only in Tow Vehicles
 > GM's Max Trailering Package
jthrv
Los Angeles
Posted: 10/26/20 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Spend some time with Ford's website build and price. For the truck I want, regular cab, V8, 4x4, XLT, manual seats, trailering, there is Not a significant difference in MSRP between 1/2 and 3/4 ton trucks. There is a big difference in the trucks curb weight, so MPG will be very different.
* This post was last edited 10/26/20 07:09am by jthrv *   View edit history
kellem
Shenandoah valley,VA
Posted: 10/26/20 06:11am Link  |  Quote  |  Print  |  Notify Moderator
As others have said, get a 2500/250 and eliminate the guess work....much more truck for not much more money.
I daily drive a F250 without complaint.
Posted: 10/26/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
When looking at GM half tons, the NHT gets a 9-3/4" ring gear axle. Standard trucks are still 8.6" I beleive. However, there are plenty of them with 9.76s that aren't labeled NHT/Max Tow. IE, like Fords, you CAN get the heavier axle without the special package. Rest of the truck is the same.
2017 Heartland Torque T29
ksss
Eastern Idaho
Posted: 10/26/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Just because it is zero degrees outside and I don't feel like freezing yet, I built a 2020 half ton Trail Boss crew cab with 6.5 box LT with a 6.2L. The tow capacity says up to 13,400 and a bed capacity of 2,250. I am sure this is with an double cab version not a crew cab, but it wouldnt be too far off. The build price was 53K comfortably loaded with tow package and all the tow cameras available. I don't think you need a 2500 HD to pull 8K unless you want to and you clearly don't. The 6.2 is a heck of motor and with that 10 speed it makes it that much better.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
We'll See
IL
Posted: 10/26/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
If you are towing in the mountains a lot and want to stick with a half ton, Ford's 3.5 ecoboost will be hard to beat. However, GMs's 6.2 liter v8 is a great motor as well but I would rather have the turbo. For what you are asking, the right half ton will do the job but you must be sure it has enough payload.
Sold - 1994 Flagstaff Cobra 206
2017 F150 SCREW 2.7 Ecoboost
2007 Honda Odyssey
Sold - 2007 Chevy Trailblazer - 5.3 & 3.42
Lund Boat
rmnpcolorado
Madison, WI
Posted: 10/26/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Let me throw you a softball: WHY would you rather have the turbo over the 6.2 “pure grunt” as I’d call it? Just an honest question, I don’t think there’s a wrong answer and in no way am I knocking the 3.5L eco.
Truth be told, our 5.3 in the Av had plenty of power this summer with our current load, it was more the tranny that I was watching the temps on.
And just for those saying I should look at at 3/4 ton, I’m not asking about those and I don’t want one at this time. A 1/2 ton decked out the way id like (not Lariat, not LTZ/Denali) already pushes the upper eschelon of our budget. Your “not a lot more” IS a lot more. Do I hear you when you say it’s a better towing experience? Yes I do, and someday I’ll listen When I feel I have that need. Today is not that day, thanks.
2020 Ford F-150 3.5L w/Max Tow
2011 Jayco X213
blt2ski
Kirkland, Wa
Posted: 10/26/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
An advantage to a forced induction motor like the Ford eco boost, a majority of dusel motors, is the fo not lose HP at higher elevations like a natural aspirated motor like the GM V8,s, Ford's 305 etal. They lose 2-3% ofHP per 1000' above sea level you go. So at 10,000' like you are at highest points in Yellowstone as an example, that 6.2 is down some 30% hp, the turbo version is still cooking along at potential max HP.
I took the same trailer, etc thru Yellowstone with a 454, 9 years latersame trailer, older teens about 1500 total lbs heavier with a GM 6.5 turbo with 50 less HP, it smoked the 454 going up the same 15% grades at 9-10,000' that the 454 could not do but in 1st gear ofits 3 so auto. The diesel with 5 gears, di it in third, or equal of 2nd with the auto. 10-15 mph faster.
Having a turbo at elevation helps.
Marty
Check RV.Net Blogs at: blog.rv.net
mooky stinks
Cicero,NY
Posted: 10/26/20 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
People that say 1/2 tons and 3/4 tons are the same price have to stop comparing msrp and actually try to get 10K off a comparable 3/4 ton. They'll kick you out of the dealership! Remember, I said comparable, not a Denali or Platinum diesel.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
9600lbs scaled
JCK
Ohio
Posted: 10/26/20 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
JCK wrote:
Had a 2015 Max tow GMC 1500 If memory serves me wright it had 4300 lb. rear axle and around 1800 payload . I think the standard rear axle is 3850 lbs. I had a 28 foot Keystone bullet that was right around 6500 lbs. Truck handled it fine but you could never drive with one hand . Trailer didn’t sway but truck was constantly moving around probably because it had 20 inch P rated tires . I don’t get it you buy max tow / max payload and they give you P rated tires shame on GM . Kept it two years and got a 2017 GMC 2500 HD problem solved
That’s a nice excuse to convince the wifey you need a Duramax Denali, but you and I both know that the tire store coulda fixed that problem for less than $1000. Or you could just air them XLs up to 50+ psi in the rear and solved most of your “issue” for free!
Grit Dog
The tires that came on my 2015 NHT max payload with 6.2 and a eight speed were those wide 20 inch tires P series I had them aired up to the max to no advail . At that time you couldn’t buy a LT tire in that size. So it would have required a rim change also.
We’re not your local traveler we’re you can get buy with what you have.
Two trips out west first to Oregon 7200 miles
Another to Black Hills , Devils Tower ect 4500 plus miles . There’s a reason you don’t see half tons out West . The wind is always blowing hard and the grades are long and steep. Buy the correct product for the the Job and enjoy the ride
Jeff K
I drank the Pink coolaid once and will never buy a 1500 again
1989 Ford Diesel
2002 HD 2500 8 liter 498 Cubic inches Allison 5 speed trans
2004 HD 2500 Duramax
2015 GMC 1500 6.2 eight speed
2017 GMC 2500 Duramax five speed
2019. GMC 2500. Duramax six speed Best truck of all of them
2019 GMC Denali 2500 Duramax
2018 Grand Design Imagine 2500 RL
rmnpcolorado
Madison, WI
Posted: 10/26/20 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Marty
That’s perfect, thanks! I think I’ve heard that before, but that helped clarify it well.
