RV.Net Open Roads Forum: Class A Motorhomes: Deep Cycle Battery Suggestions
 > Deep Cycle Battery Suggestions
stugpanzer
Illinois
Posted: 10/26/20 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
I might need to get two 12 volt deep cycle (house) batteries for my coach. I have been looking at going with gel batteries but I am curious if anyone else has gone that route and have suggestions for what I may want to look at.
2006 Fleetwood Pace Arrow 37C
Mods: EEZRV Products TPMS, Cobra 29LX 50th Anniversary CB radio with Firestik NGP Antenna, Self contained sewer hose
theoldwizard1
SE MI
Posted: 10/26/20 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Much better off with two 6V golf cart batteries.
AGM 6V golf cart batteries do exist but they are $$$ (Trojan T105-AGM) and would have to be ordered through a golf cart store or solar power store.
Ed_Gee
Central Oregon coast
Posted: 10/26/20 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't mind checking battery cell electrolyte levels and battery corrosion cleaning then two GC-2 6V batteries would do just fine. Otherwise I'd suggest two 12V AGM batteries like Renogy 12V 100Ah units...
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
stugpanzer
Illinois
Posted: 10/26/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I need to double check and see if my two house batteries are 12volt or 6volt. Thanks for the input!
time2roll
Posted: 10/26/20 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Stay away from GELL. Need special charging to limit voltage and amps.
Get AGM if you want no maintenance. I recommend Lifeline.
Otherwise a couple flooded batteries from Costco is a good value.
Or is there something special we should consider in the recommendation? Two batteries seems light for such an RV but maybe you are almost always plugged in.
675w Solar pictures back up
stugpanzer
Illinois
Posted: 10/26/20 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the tip. This coach is set up for two batteries and yes, we do stay plugged in most of the time.
pianotuna
Regina, SK, Canada
Posted: 10/26/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If you want possibly the toughest battery available, look closely at SiO2 chemistry. This is what I've gleaned so far:
They can be discharged to stone bone dead 620 times without dying. After those 620 cycles, 80% of OEM capacity remains. They are about 1/2 the price of LI. They can be used and charged at -45 c to +65 c. (-49 f to 149 f)
At 50% discharge cycles are 2800 (80% of OEM left)
At 80% discharge cycles are 1500 (80% OEM left)
They can be draw on at a rate of 9C for 5 seconds.
They do not need to be recharged to 100%, but once a month a full charge is recommended.
From the seller:
“This battery has 1200 Watt Hours of storage.
You can access 100%, but it is recommended that you do not regularly discharge over 80% because it will shorten the lifespan of the battery.
At 80%, the usable capacity is 960 Watt Hours of storage. Max peak discharge is, (for the 100 amp-hour) is 900A (5s) at 25 degrees C.
Constant Amp discharge rate is 320A (about 5 minutes until the battery is fully discharged). For charging the rate is .25C (4 hour) charge rate (25A for 1 100Ah 12V battery).”
The only negative is weight. The "best buy" is currently the 100 amp-hour battery."
For USA pricing go here:
https://azimuthsolarproducts.com/product-category/batteries/sio2/
I've found the Azimuth company extremely responsive to questions, often replying on the same day.
The manufacturer is the Canadian company https://soneil.com/
Technical Brochure is:
https://soneil.com/wp-content/uploads/2018/07/12-EFSN-100.pdf
Regards, Don
Ed_Gee
Posted: 10/26/20 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Not really a problem going either way. If you get two 6v batteries you just wire them in series.
midnightsadie
ohio
Posted: 10/26/20 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
plugged in most the time? get two wal mart deep cycle marine, the biggest that will fit. mine are four years old and work great. and you won,t break the bank.we some times boondock for a week end no problem.
Ray,IN
IN, USA
Posted: 10/27/20 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
I use 100A Delco batteries from Sams Club, likely the same battery different label.
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
