Lynnmor
Red Lion
wintersun wrote:
Diesel provides greater fuel economy but the total cost of ownership is double that of a gas powered vehicle.
Anybody really believe that?
goducks10
There
After owning both I fail to see the dbl the cost. A couple fuel filters is all thats different. The better mpg's of a diesel will cover that.
Oil changes on new diesels are longer than gas. Syn oil for gas trucks is not cheap.
All other maintenance is the same.
Sjm9911
New Jersey
Good luck with it. They do make the longer trips way easier.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
fj12ryder
Platte City, MO
I guess it's possible, my Dodge uses fuel filter that my Hyundai doesn't. The tires are much bigger, the air filter is more costly, differential fluid that the car doesn't have. Brakes are a bit higher,
So my annual maintenance for the Hyundai is about $35, and the Dodge is about double that at about $85. So yeah, maintenance costs are about double.
Howard and Peggy
"Don't Panic"
RoyJ
Vancouver, BC
Highly depends on the engine, and its failure rate.
Compare a 6.4 PSD, vs a 5.4 or 6.8 Triton for 300k miles, the diesel can easily double the cost. Major failures are when, not if. Most repairs cost as much as an entire used 5.4 longblock.
A late Cummins 5.9? Your ownership is probably lower than a Hemi / V10. Of course, we can go the other extreme, some BMW / Mercedes / Jaguar engine can match a 6.4 PSD in repair costs.
