RV.Net Open Roads Forum: Towing: Short Steep or Long gradual
Search only in Towing
Open Roads Forum  >  Towing
 > Short Steep or Long gradual
PWRmx24
Virginia
Posted: 10/31/20 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Towing maxed out from West VA in a 96 F350 7.3L. Trying to decide if I go over mountains using route 60 to Amherst VA or I64 east toward's Charlottsvile to lynchburg. My post is not so much about the exact route as much as the dynamics of the route. One is winding and steeper....harder slow pulling constant turning and at very low speeds. But on the other side of the mountain at least if I lost brakes I can put it in the bank and live. The other route is more gradual but if I lost brakes on the other side theres no runaway ramp and it's a ways down.
Any thoughts appreciated.
JRscooby
Indepmo
Posted: 10/31/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
First thought? Make sure your brakes are in good shape, baby them so you don't loose them.
opnspaces
San Diego Ca
Posted: 10/31/20 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Take the easiest route with the least amount of steep downhills. and
Use your gears to descend the hills. Here's a test with no towing involved. It's merely to see what gears you can use at what speeds.
Go driving with just the tow vehicle and no trailer. Go find a bit of road that you can accelerate to 60mph without endangering yourself or others.
Safely stop the vehicle and pull the shifter down into the lowest gear. Accelerate until 15 - 20 mph and then shift up one gear on the shifter.
Can you drive 60 mph in that gear without getting within 500 to 700 RPM before the red or orange markings on the tachometer? If not shift up until you can drive 60 mph while still being below the red or orange markings on the gauge. The idea is to find the lowest gear (2nd, 3rd, 4th, fifth etc) that you can drive at 60 without letting the tachometer get to the orange or red markings. Once you find this gear you know that you can downshift to this gear on a hill and not damage your engine.
Let's say your truck is like my Suburban that I can run 65 mph in 2nd gear without hitting the orange or red marks. When I crest a big hill like the grapevine I just use the brakes to slow down to about 50 mph. I then shift the transmission selector to the 2 position and take my foot off the accelerator pedal and away from the brake pedal and just start to coast down the hill.
As I go down the hill the speed will slowly start to increase. But, since I'm in 2nd gear it behaves like I have my foot on the brakes which I don't. When the speed climbs up to about 58 mph I put my foot on the brakes and firmly press to slow the vehicle down to 50 mph again. Once I get to 50 mph I take my foot off the brake and start coasting again.
I usually only have to touch the brakes three maybe four times for a hill the size of the grapevine. While it may seem like this is stressful it is usually just the opposite. With the transmission in a lower gear I don't have to watch the speed like a hawk. Instead it just goes down the hill as if I'm dragging a parachute behind me and only speeds up slowly
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
RoyF
Fayetteville Arkansas
On a long downhill grade, select a low enough gear so that you touch the brakes only once in a while. (And turn on those flashers when driving less than 50 mph.)
Make sure that the trailer brakes are properly adjusted.
Cummins12V98
on the road
Posted: 10/31/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
If you don't have get an exhaust brake and don't worry.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Near DVNP, California
Posted: 10/31/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Maxed out towing isn’t fun. RVing should be fun. Fix the issue.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Super_Dave
Harrisville, UT
Posted: 10/31/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
The stress and strain of steep makes me worry about things a lot more expensive than brakes. I take the gradual every time.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
BarneyS
S.E. Lower Michigan
Posted: 10/31/20 08:38am Link  |  Quote  |  Print  |  Notify Moderator
I would take the less steep downhill route even though it may be long. The 7.3 diesel will not hold you back much at all without an aftermarket exhaust brake so you need to start at the top of the grade very slowly in a low gear and use your truck and trailer brakes off and on to keep the speed slow. Don't let it build up on you.
I had a Ford 7.3 for years (2002 - 2016) and it was a great motor for reliability but not so much for power compared to newer motors. I also added an exhaust brake for a couple of years but it failed twice so I disconnected it and never had a problem descending grades as long as I did as described above.
Barney
Not towing now.
Vw triker
Millboro, va
Posted: 10/31/20 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I would not go rt 60, I would go 220 to Roanoke, then 460 to lynchburg.
I have used all three routes, like 460 much better.
ferndaleflyer
everywhere
Posted: 10/31/20 08:53am Link  |  Quote  |  Print  |  Notify Moderator
My daughter went to college in Lynchburg and I lived at the time in WV and used each of those routes many times towing her horse trailer many times with a Chev diesel with no exhaust brake---I 64 no question!
