RV.Net Open Roads Forum: Class C Motorhomes: How cold is too cold?
 > How cold is too cold?
coolmom42
Middle Tennessee
Posted: 11/10/20 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
steveh27 wrote:
My Class B has the same setup with the fresh water tank and pump under the bed. So it is inside, but because the space is sealed from the heater outlets it does not get direct heat. That did cause a problem when it was 8 degrees and the lines from the pump to the tank froze. I lifted the bed to allow air in and put a few chemical hand warmers on the affected areas. It was good after a few hours as the day warmed a bit.
But it is not a problem with the temps you expect.
Good to know that works!
I think if I am staying somewhere and temps drop, I could put an incandescent lamp in the basement space that it is under and adjacent to the tank and water pump. Not a heat lamp, those things are dangerous. But just a regular small lamp.
Of course that assumes a person could find a real incandescent bulb easily. A small space heater would work, too.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
time2roll
Posted: 11/10/20 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Good place for a small pipe heater. (assuming you are plugged in)
https://www.ultraheat.com/ultraheat-am-ph513
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 11/10/20 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Coolmom42,
I use one of these near my water pump:
http://www.moistureking.com/
I have it plugged into a mechanical thermostat.
Regards, Don
gkainz
Arvada, CO, USA
Posted: 11/11/20 06:56am Link  |  Quote  |  Print  |  Notify Moderator
memtb wrote:
ppine wrote:
Too cold, starts around zero, and gets worse from there.
It has been -38 degrees F in my driveway.
I’m a newbie to Wyoming, @ only 35 years.....the coldest I’ve seen was -47 F. Thankfully, there was zero wind.....but, I had an outside job. And.....I’m darn glad we weren’t rving that night! memtb
When is there zero wind in Wyoming? Everyone fell down? [emoticon] (worked a lot in Wyoming back in the '70s).
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
memtb
Wyoming
Posted: 11/11/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Actually there are times, thought rare, we have little to no wind. It very rarely happens in the I-80 corridor.
That particular night, I was working about 30 miles east of Kemmerer.....Shute Creek Gas Plant.
We live near Worland, Wy......the lowest wind average in the state. In our hot summers, you often pray for a breeze! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
ppine
Northern Nevada
Posted: 11/11/20 08:40am Link  |  Quote  |  Print  |  Notify Moderator
IN Wyo an old piece of anchor chain makes a good wind gauge.
Working out of pickups all the time, the one cardinal rule is never open both doors at the same time.
In Laramie the snow drifted all the time. Sometimes people came out of an upstairs window.
Once your hear the snow squeak at -25 degrees you never forget it.
In the winter, I used to play chess late at night with a guy that had a PhD in wildlife biology. We used to drink vodka and watch the ice form on the inside of the windows at 30 below.
