RV.Net Open Roads Forum: Internet for campsite and while en route (travel trailer)
 > Internet for campsite and while en route (travel trailer)
coolmom42
Middle Tennessee
Posted: 11/02/20 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Raife wrote:
coolmom42 wrote:
Wilson makes the best cell phone signal boosters. This is the version for vehicles. I think you could get one booster unit and 2 outside antennas. Attach one outside antenna to the truck and one to the trailer, and move the booster unit back and forth as needed. They are not cheap but they work well.
This was the solution I arrived at last night (after midnight) as I was scouring the internet for options. However, I plan on keeping my Sprint phone for now (S20 with a 50 GB hotspot). That may change...
Someone mentioned our route as a factor (which I recognize is huge)...what really kicked this into gear to be done RIGHT NOW is we are leaving on the 18th for 2.5 weeks to go from central Texas to Sacramento California (visit in-laws) and back. We will be sticking mostly to stops along major highways with the exception of Grand Canyon and Zion.
However, when we usually "camp" (i.e. not going to somewhere) we typically hit state and national parks. I am fully aware that many of these are not "ideal" for cell signal, in fact that is partly why I do it. It will be a balance of timing going forward - cell areas during school, non-cell areas when there is no school.
Thank you for all the info.
If you are travelling, you absolutely need to switch to Verizon. Sprint service is going to stink, anywhere outside of larger cities. Verizon has by far the best nation wide network, and the best coverage in rural areas. ATT is a distant second best.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 11/03/20 02:17am Link  |  Quote  |  Print  |  Notify Moderator
I've found that putting my phone/hotspot **outside** the RV works better for keeping a signal.
If you're too far out in the boonies, you'll need one of the $300+ boosters.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
way2roll
Wilmington NC
Posted: 11/03/20 06:21am Link  |  Quote  |  Print  |  Notify Moderator
coolmom42 wrote:
Raife wrote:
Interesting, We have ATT and have friends with VZ that often can't get a signal when I can. I think differences in ATT and VZ are splitting hairs more than being vastly different in terms of coverage. If travelling a lot, having both majors - ATT and VZ should have you covered.
ktmrfs
Portland, Oregon
Posted: 11/03/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
coolmom42 wrote:
In our traveling I'd agree with you on Verizon vs. ATT. We have both, truck has ATT our cell phones are verizon. There are many places with good coverage on either, and places one or the other works. And for us quite a few places that neither is available even with a booster and yagi antenna.
2011 Keystone Outback 295RE
philh
Belleville MI
Posted: 11/03/20 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
I'm an OTR customer using a netgeat nighthawk with two high gain antennas.
This is an interesting video from full time RVers that need solid internet connection
https://www.youtube.com/watch?v=yDCIx5JpEgs
Crabbypatty
Long Island, New York
Posted: 11/04/20 03:45am Link  |  Quote  |  Print  |  Notify Moderator
Rv's are metal boxes that block radio tv signals. So you need a good outside antenna. Alot of RV roofs, like mine are EPDM ie rubber. Antennas need a good ground plane, ie metal. When selecting a roof antenna for omni or circular direction meaning you need to aim the antenna, the Wilson Trucker works well. If you know where the cell tower is and want faster service especially if your distant from the cell tower then you need a yagi antenna to aim at it. I have both as it depends are where you are in relation to the cell tower. There are apps and websites that tell you where the towers are and what service they have ie VZ ATT etc. My outside antennas are connected to a Wilson Extreme RV amplifier and and inside antenna. Radio signals, as that's what a cell phone is a two way radio are subject to interference, obstacles and distance as well as the cell phone tower it self may not be transmitting well. Both of my antennas are mounted on a painters pole, power clamped to the ladder. Height is might as hams say the higher the better.
So if your out in the open and can see the tower you probably can stream Netflix, if you cant, hills trees buildings or you parked next to a beautiful class a moho, you may get nothing. Same for CG wifi outside antenna, amplifier and inside antenna. I carry both systems not knowing which one will work best. Now if both systems cant get a signal or I don't need to work, either pick up and move, select a better cg or location, if not then pop a beer and throw another log on the firepit. Happy Trails
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
Raife
Posted: 11/05/20 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. I have scoured the Mobile Internet Resource Center and asked a couple questions over there. I bought a weBoost Drive Reach, but through research realized it only boosts a single signal and therefore forgoes any MIMO advantage (i.e. it could actually hurt your speeds). I also have done some analysis on usage and we will likely not make it on my phone's hotspot.
So I stepping up my options given the total cost of the dual setup I was considering. I'm leaning toward the Pepwave MAX BR1 ENT (which comes with 2 internal antennas for now) or MAX Transit PrimeCare and then a PoE Access Point (like this one) and then an unlimited SIM (likely ATT or Verizon) for monthly access when we need it.  This way I get the flexibility and power of cellular router (with CAT12 or 18 modem respectively) and the location (i.e. front of trailer) for the access point to the tow vehicle.  I can add an external roof antenna if needed for better reception.
Thoughts?
* This post was edited 11/05/20 07:50pm by Raife *
