rmauk
Pennsylvania
Newbie here. Due to freezing temps, I want to run the furnace on low but with all water drained, but not winterized yet. How do I run the furnace but not the hot water tank?
schlep1967
Harrisburg, PA
Turn off the water heater at your control panel or wherever your water heater on off switch is.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Lone Pine, CA weather permitting
Is your water heater and furnace separate appliances? What year, make and model is your TT?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
time2roll
The two appliances have independent controls.
675w Solar pictures back up
2oldman
south
huh?
K Charles
Connecticut
When you buy it ask during the walk thrugh. Easiest way is to turn off the switch. What kind of water heater is it?
bukhrn
Lanexa, Va
rmauk wrote: Newbie here. Due to freezing temps, I want to run the furnace on low but with all water drained, but not winterized yet. How do I run the furnace but not the hot water tank? Did you drain the water heater?
2007 Forester 2941DS
2014 Ford Focus
Old-Biscuit
Verde Valley
WELCOME!!!
Water heater.....has separate controls. Gas On/Off switch inside (could have electric also inside or in outside compartment)
Brand/Model??
Furnace.....controlled by Thermostat on wall
Select HEAT
Turn temp set point UP to desired temperature
Fan comes on...slight delay/runs to purge combustion chamber then should hear 'Click, Click, Click' from ignitor/electrode then Flame comes on
Heats to temp set point...flame goes out...fan runs for cool down cycle then repeats when room temp drops 2-3* below thermostat set point
Brand/Model of Furnace and Thermostat would be helpful for us to help you
Also should post Year/Brand/Model of RV
rmauk
Pennsylvania
Thanks to all who replied.
ReneeG
Meridian, Idaho
You didn't answer if you drained your hot water heater. I'm suspecting you didn't. Keep that on as well if it's going to freeze for several days or drain it. You pull the plug - the anode rod - and let it drain to the outside. Look it up on YouTube.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
