RV.Net Open Roads Forum: Toy Haulers: Hitch weight vs payload
Search only in Toy Haulers
 > Hitch weight vs payload
WV Camper
Salem, WV
Posted: 11/02/20 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have anew 2020 Chevy 3500 SRW with the Duramax engine. The payload on the door is 3769 but the hitch weight for gooseneck (and 5th wheel?) is 3180. Does anyone know why this is so much lower than the payload number? We would like to have the Montana high country 383TH, the hitch weight is 3225. So, this is a miss by 45 lbs. how much lighter would you expect the pin weight to be with my 850 lb motorcycle in the back?
valhalla360
No paticular place.
Posted: 11/02/20 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Could be the rear axle rating.
- Payload may assume some of the load is going on each axle. So the front axle is providing some additional payload.
- 5th wheels Pin Weight goes pretty much 100% on the rear axle, so it may max out the rear axle at 3180.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
rhagfo
Portland, OR
Posted: 11/03/20 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Well another 17,000# GVWR 5er I want to tow with a 3500 SRW.
I assume you understand that that Payload number on the door sticker, include everything that is carried in the TV. That is passengers, add-on accessories, Hitch, and anything else carried in the passenger compartment and bed.
The difference between those two numbers is 589#, maybe they are taking into account some averages. then they may be taking into account the rear axle rating. The payload wars are pushing all the limits, TV GVWR's now days are a very high percentage of total axle rating, making it possible to be within payload number and exceed rear axle rating.
You have the truck, take it to the scale ready to tow and weight both axles, take that total and subtract from the listed TV GVWR, that is what you have left of total payload. In addition take the scaled rear axle weight and subtract from the rear axle rating the lesser of those two should be maxim pin weight you can carry.
Please post back GVWR, and both front and rear axle ratings.
azdryheat
Tucson, AZ
Posted: 11/03/20 09:57am Link  |  Quote  |  Print  |  Notify Moderator
When I had my truck weighed with and without the toy hauler, the front axle weight was the same telling me none of the trailer's weight is on the front axle.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
JIMNLIN
Oklahoma
Posted: 11/03/20 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Where did the 3180 lb GN/5th wheel number come from ??
The payload sticker is GVWR based number that may overload a trucks RAWR if its used as hitch weight. Like many 4xxx lb sticker numbers on any 350/3500 SRW trucks.
Your 3500 SRW shows to have a 7250 RAWR for 2020. Looking GM weight calculator website shows the high country optioned 2wd crew cab long bed Dmax rear axle weighs in the 3400-3500 lb range. Doing the math shows the rear axle in the bed payload may be around 3700 lbs for a max payload before exceeding a wheel/tire/rear spring pack capacity.
You have the truck so like all truckers load the truck up and drop by the local CAT scales and weigh the trucks front and rear axles separately. That way you know your exact numbers.
Old-Biscuit
Verde Valley
Posted: 11/03/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Truck payload is based on trucks GVWR minus the trucks UVW
Payload is for ALL added weight and spread over both F/R axles of truck
Pin weight of gooseneck/5vr is 'carried' by trucks rear axle
That 3225# 'hitch' weight you posted is DRY pin weight based on the DRY weight of that Montana TH
DRY (shipping weight) 13,880# with a DRY pin (hitch) 3225# = 23% pin ratio
17,000 GVWR TH using a 23% pin ratio = 3910# WET Pin
Your 2020 truck with 7250# RAWR could handle 3400# WET Pin
So you really should be looking at THs with a GVWR of 15,000 for that SRW Truck
arhayes
Posted: 11/03/20 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Would you believe, the pin weight of our 43', 19,400 GW TH is within 20 pounds whether our Goldwing in on board or not. It is right at 4200 lbs. I would not plan on a significant change.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
WV Camper
Salem, WV
Posted: 11/04/20 04:08am Link  |  Quote  |  Print  |  Notify Moderator
An actual answer to my question- thanks!
JIMNLIN
Oklahoma
Posted: 11/04/20 05:35am Link  |  Quote  |  Print  |  Notify Moderator
Actually you have two questions...and you got actual answers to both. Your last question cannot be answered with the exact weight as way too many variables. I don't have your exact trailer but from loading dozens of flatbed trailers/enclosed trailers/stock trailers I would agree with the poster that answered your last question.
lincster
Mesa Az
Posted: 11/04/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Agreed.
I have CAT scaled my setup multiple ways.
Truck only.
Truck with empty toyhauler.
Truck with full toyhauler.
My front axle weights on my truck only changed by 15 lbs, no matter the configuration.
2019 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
