RV.Net Open Roads Forum: Roads and Routes: James Island County Park Charleston SC
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > James Island County Park Charleston SC
Esacnj
NJ
Posted: 11/03/20 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Is there an alternate way in to avoid the low hanging trees that everyone seems to talk about.
Mayor30
Pa
Posted: 11/03/20 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Not that I know of. We have a TT that's about 11.5ft high and had no trouble. I saw some larger 5th wheels and motor homes there so I assume they didn't. I know our GPS took us in one way but we preferred to go in
and out on 700 and Riverland Dr. There is no way to avoid Riverland Dr but like I said we had no problems.
Crabbypatty
Long Island, New York
Posted: 11/03/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
We are heading there after the year turns. Now pulling a 13'2" tall fifth wheel. I will be calling the park to find out more.
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
kohldad
Goose Creek, SC
Posted: 11/03/20 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
I will offer two options and recommend you do a virtual drive on Google Maps of both to figure out which you prefer.
Take James Island Connector (hwy 30) and turn left on Folly Road. Right on Camp Road. Right on Riverland Drive. Left into the park. Biggest problem with this route is the right turn onto Camp Road as it would be tight.
Take James Island Connector (hwy 30) and turn left on Folly Road. Right on George L Griffith Road. Right on Riverland Road. Left into park.
I do not recommend using Central Park Rd because of the left onto Riverland which is usually bad enough in a car but can be done with RVs as I see them all the time, just takes patience. Also will warn that at above normal high tides, the road does flood with salt water but not to the point it can't be driven.
Riverland Dr has a bad reputation which is deserved to the drivers not paying attention. The old large oak trees have the scars to prove it. However, if you pay attention, don't ride the white line and you will be fine.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
TxGearhead
Posted: 11/06/20 04:09am Link  |  Quote  |  Print  |  Notify Moderator
What he said^^. Our 5th wheel is tall, 13' 3", and getting in the park was a challenge but we did it. Had a TT following us in and talking at check-in he couldn't believe we made it. Having been there once, I'm not going back. Trees grow. They don't seem too motivated to trim them.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
