RV.Net Open Roads Forum: Tow Vehicles: Battery problem
Search only in Tow Vehicles
 > Battery problem
jornvango
Full-time RVer
Posted: 11/03/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
2013 Chevy Tahoe with 120K miles. Battery was last replaced Jan '17.
For the past 8 months, especially after a cold night or when we haven't driven the car for a day or two, the car shows low battery level indicator and has trouble starting (but hasn't left us stranded ... yet).
A few months ago my wife left an interior light on which drained the battery enough so the car didn't start. We charged it by hooking up our solar panel to recharge it.
A few days ago after a very cold night (10 F), the battery was so low (as indicated by the gage on the dash) that it barely started.
Yesterday morning, after overnight temps around 35 F, again the battery level gage showed low and the car barely started.
We have been to Autozone / O'Reilly's multiple times and every time the battery, alternator and starter tested 'good'.
This morning I plugged a volt meter into the car. It again had trouble starting. Here are the readouts:
1. Before car start in the morning 12.0 V
2. During start 10.8 V
3. Started the car and during driving 14.7V
4. Stopped the car after driving 30 mins 12.5V
5. After 1 hour of not running 12.2 V
Any idea what is going on? It reallyfeels like one of these mornings the car is not going to start which will be a problem if we're camping off grid.
Thanks!
Roger10378
Goodrich, MI.
Posted: 11/03/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
What happens if you let the battery charge longer? 30 mins of driving is not enough to bring a battery up from 12.0V to fully charged. A fully charged battery is 12.7V.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Krusty
Calgary, Alberta,Canada
Posted: 11/03/20 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
You should get a battery charger and charge the battery up fully. Also, if the battery and charging system test good, perhaps there is something drawing the battery down overnight.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Lynnmor
Red Lion
Posted: 11/03/20 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Family member has a Tahoe that is a few years older that had a similar problem. Turned out to be in the instrument panel so a complete replacement was the fix.
jornvango
Full-time RVer
Posted: 11/03/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Would a 'complete replacement' mean replacing the Tahoe, its instrument panel or just the battery? [emoticon]
jornvango
Full-time RVer
Posted: 11/03/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
We ended up driving a few hours today. Upon arrival at our campsite, the battery showed 12.2 and a few seconds later 12.0
Is there any way to test if there is a draw on the battery while the car is turned off?
Slownsy
Posted: 11/03/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
.The battery has had it
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
Turtle n Peeps
California
Posted: 11/03/20 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Do an amp draw with a meter.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
4x4ord
Alberta
Posted: 11/03/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
I think your battery is pooched.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
CA Traveler
The Western States
Posted: 11/03/20 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
A DC clampon meter will do the job, just takes a few seconds to display the draw or charge. Make sure to get one that measures DC amps. Most can display AC as well.
2014 Grand Cherokee Overland
Bob
 > Battery problem
