blaczero
Hey all, I think I know the answer but just wanted to make sure. I am looking into a 5th wheel ~15k GVWR and am buying a truck. I want an f350 and may order a new one to get exactly what I want (there are currently 0 trucks nationwide that match what I want).
I am going F350 DRW, 7.3L gas, crew cab 4x4 with 5th wheel prep. What I'm thinking is I'll go 4.10 axle ratio.
I work from home and my wife cannot work, so it's a "daily driver" but won't be driven daily. To make our dream work, we'll sell our vehicles and this will be our only one.
So bottom line, should I get the 4.1 ratio or the 3.73?
South of Lone Pine, California
3.73 would be fine particularly for a daily driver IMO. However you don’t indicate a home location or where you travel.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Old-Biscuit
Verde Valley
Slightly better MPG with the 3:73
Better towing with the 4:10
With that 10 speed tranny....go 3:73
rhagfo
Portland, OR
Well tow rating with 3.73’s is 17,000#, with 4.30’s (4.10’s not an option) about 19,000 to 20,000#.
I think I would want 4.30’s.
blaczero
rhagfo wrote: Well tow rating with 3.73’s is 17,000#, with 4.30’s (4.10’s not an option) about 19,000 to 20,000#.
Right, 4.3 not 4.1 thanks. Ya just looked at the book again, goes from 16k with the 3.73 and 20k towing with the 4.3.
How much of a gas mileage hit is it to go to 4.3? We talking 1mpg? or like 5?
rhagfo
Portland, OR
blaczero wrote: rhagfo wrote: Well tow rating with 3.73’s is 17,000#, with 4.30’s (4.10’s not an option) about 19,000 to 20,000#.
Well we went from a Ford 460 to Dodge CTD and doubled my mileage!
1988 F250 460 with C6 auto, to a 2001 Dodge Ram 2500 CTD 5.9 with 5 speed and 3.55’s went from 7 mpg to 14 mpg in town.
Current Ram 2016 3500 DRW Aisin, 3.73’s about 12 around town. Tow capacity 25,024# doubt I will ever drive a gasser again.
stickdog
Somewhere, USA
Unless your crawling up mountains all the time stay with the 3:73's.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
bucky
Raleigh metro
How much does your GCVWR impact your tax and registration costs? With a 10 speed trans the old opinions regarding axle ratios no longer apply.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
MFL
Midwest
Since you are buying a DRW gas engine tow vehicle, you will want the most towing capacity, which means the 4.30 ratio. Having 4K more tow capacity is a huge benefit to a gas DRW TV! Even using it for everyday use, you likely won't be able to measure the mpg difference, with 10 speed. If towing the mpg may be better with the lower gearing, but certainly not worse.
In any case, it will be a big capable truck! I'd be more concerned with reliability, and how it rides, rather than mpg.
Jerry
valhalla360
No paticular place.
Since the OP said, he's buying a 15,000# trailer, either are well within tow ratings.
With the 10 speed transmission and being well within ratings, the axle ratio isn't critical for towing. This is different from the old days of 3 & 4 speed transmissions where if you couldn't hold top gear, your RPM went thru the roof if you had to downshift and that ate into MPG. With 10 speeds to choose from, the truck will pick the gear that results in the best engine RPM while towing regardless of axle ratio because it has enough gears to find one that provides that RPM.
When running empty, you will likely get a boost in MPG. One thing to be careful of with big trucks is 1 MPG going from 12 to 13 MPG is an 8% improvement. Improving a 50 MPG car by 3 MPG is only a 6% improvement. Small numerical changes in low MPG vehicles make a much bigger difference.
Now if the OP wants to exceed 17,000#, that is when jumping to the 4.30 starts making sense.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
