RV.Net Open Roads Forum: Fifth-Wheels: Axle Ratio, new truck
 > Axle Ratio, new truck
Page of 5
valhalla360
No paticular place.
Posted: 11/05/20 05:32am Link  |  Quote  |  Print  |  Notify Moderator
BurbMan wrote:
valhalla360 wrote:
Terryallan wrote:
There really is a reason that lower gears are rated to tow higher weights. Something to do with physics
Explain the physics for us when both options are well within tow ratings.
That's easy...when you operate at a lower % of the rating, you place less stress on the machinery.
valhalla360 wrote:
If you have a 4x4 and are having difficulty backing into a site...drop it into 4-Lo and you will have far more torque than the 4.30 gives in 2-High. But really, that's a pretty rare issue. Most people towing 15k 5th wheels aren't backing up 20deg inclines.
4-lo is Ok sometimes, but not when you have to steer on pavement. What about bumper to bumper traffic when you are caught on the uphill going over a bridge at 5 mph? Taller gears like the 4.30's mean less strain on the transmission. What gears do you have in your F250?
When you are well within the tow ratings (as the OP suggested with either rear end), the truck is not being unduly stressed. The engineers made sure it was fine. By your logic, you should get a class 10 semi-tractor because that would reduce the stress on the drivetrain parts.
If you are struggling on the highway in bumper to bumper, you aren't within your tow ratings.
I have a 4.10 in my current F250 but that's because I bought used and that's what it had. More importantly, as a 2008, I only have a 5 speed transmission which is wildly different from an 8 or 10 speed transmission.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
MFL
Midwest
Posted: 11/05/20 05:59am Link  |  Quote  |  Print  |  Notify Moderator
Hey guys...like I said in my earlier post, the OP is wanting a 350 DRW truck, capable of heavy loads. This will have a huge RAWR, and a payload rating much higher than a SRW. When ordering this truck, with a gas engine, you want the most drive train tow capacity, or you are defeating the purpose of the truck. The OP is looking at a 15K GVWR trailer, does not own it. He may decide on a bigger one. It would not make sense to put a 15K hitch in it either, due to not matching the truck's capability. On a new 250, with 10-speed, it would not matter as much, which gear set.
Jerry
garyp4951
TN
Posted: 11/05/20 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Its a no brainer, 4:30 with 10 speed for the 7.3 gas F-350
Terryallan
Foothills NC
Posted: 11/05/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Lower gears put more torque to the ground. One way is by allowing the engine to turn more RPM making more HP.
another way to check how much difference a gear makes is to get on a 10 speed bike. Try to start off in 10th. then try to start off in 1st. see if you can tell a difference. I'm betting you can. The lower the gear the easier it is for the engine to move the load. Just physics
* This post was edited 11/05/20 02:59pm by Terryallan *
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
NJRVer
NJ
Posted: 11/05/20 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
X2!
That's a good real world example to use.
rjstractor
Maple Valley, WA
Posted: 11/05/20 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
A lot (sometimes too much) emphasis is placed on rear axle ratios with the new 10 speed transmissions, especially the diesels. The diesels have an insane amount of torque and can pull the higher trans gears while towing, even with 3.31 gears. The new 7.3 gas is a whole different matter. While it has great torque, it's still less than half that of the diesel. With the same trans ratios that the diesel has, 4.30 is a no brainer. If I towed that much weight I'd get a 4.56 if they offered it.
Terryallan
Foothills NC
Posted: 11/06/20 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Even with the 10 speed. First gear still has to start it all moving, and a lower gear will start it moving much easier than a high gear. That is why Lower geared trucks have a higher tow rating than higher geared trucks. There is a world of difference between a 4.10, rear, and a 3.15 rear. Even in a 10 speed. When I made rear gears. We even had a 2.15 gear. Want that in your 10 speed with 8000lb behind you?
Also my trailer truck had a 13 double over. And 1st gear would only run it to 10 mph at 2500 RPM. That is a pretty low gear, and it had one even lower when needed.. We called it the Granny gear. We never used it. Wasn't worth the time to put the shifter in it.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 11/06/20 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Here's the 1st gear ratio for GMs 6 speed Allison and the new 10 speed:
New 10 speed 4.540 : 1
Old 6 speed 3.094 : 1
So with the lower first gear the 10 speed will give you the same overall pulling power with the taller differential gears.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
rhagfo
Portland, OR
Posted: 11/06/20 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
If I wanted to pull a 15,000# 5er with a gas engine I want all the advantage I could get. The 3.73 gives 17,000# pulling capacity, 4.30’s gives you 20,000#.
My 2016 Cummins with six speed, and 3.73’s gives me 25,024# of pulling power, next 5er will likely top out at 17,000#.
goducks10
There
Posted: 11/06/20 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
You couldn't pay me to tow 15,000 with a gasser. It would be nice if you did as it would help offset the terrible gas mpg's.
Page of 5
