RV.Net Open Roads Forum: Fifth-Wheels: Leaf springs new best brand triple axle advice
 > Leaf springs new best brand triple axle advice
time2roll
Posted: 11/05/20 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
If the springs are flat I would go up about 1,000 pounds rated (pair).
If you must just get the two I doubt it is a big deal.
Are you sure it is not the flipped shackle that makes them look flat? If you can just get the weight off the springs and everything positioned right again maybe it is fine.
Can you post some pictures?
675w Solar pictures back up
rockwind1
las vegas
Posted: 11/05/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Well. I flipped The shackle back so it was correctly oriented and the spring went from having a negative curve to having more of a flat shape. The other thing that I’ve noticed over the years I never thought it was that big of a deal but maybe it is, my trailer has always been sort of angled nose down so to speak when I’m driving along in my truck, I think my truck leaf springs have slowly lost some of their capacity. I think I’m gonna get some airbags finally. But I wonder if not having the trailer perfectly level while towing has just put more weight on that front axle. It’s definitely not an extreme amount of unlevel Ness, but it is noticeable.
As far as going up 1000 pounds, I really don’t know what the leaf springs are rated out right now, I was looking at the new leaf springs and they all have white ratings but I guess I’ll have to figure out what mine are first, I thought if you just went from a four to a five or a five to a six, it would just obviously be stronger. The guys at the Sort of RV shop recommended the six leaf springs instead of my four
time2roll
Posted: 11/05/20 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
It is not just the number of leafs but the thickness and the metallurgy. Best to find the actual rating. Worth a call to the manufacturer. Usually the axle will have a tag with the rating or the model number to look it up. I would get springs that cover the full axle rating and maybe a little more. I would have to know the rating not just accept what they happen to have left over from the last job.
Example if they are 5200 axles I would be going 2750 on the springs (2750x2=5500)
Check the springs in the link I posted above.
6 leafs could be 2500 to 3800 rating
* This post was edited 11/05/20 07:52pm by time2roll *
rockwind1
las vegas
Posted: 11/05/20 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
I actually edited my opening post, they are 5080 pound axles
JIMNLIN
Oklahoma
Posted: 11/09/20 04:22am Link  |  Quote  |  Print  |  Notify Moderator
My old '97 5th wheel rv trailer has tandem 5200 lb Dexter ax;les and weighs in the 11200-11400 lb range depending on how we load it. Now subtract 2200 lbs of pin weight = 9200 lbs on the trailer axles.....or 4600 lbs per axle. I've noticed the 23 year old springs have flattened some since new. If I keep the trailer it gets new 5200 lb Rockwell American Axles like my commercial trailers came with.
Myself...I wouldn't go with a 5-6 leaf spring on a axle that small especially a triaxle.
I've pulled several tri axle non RV GN trailers and have a triaxle GN stock trailer now (7k Axles). One thing I learned through experience out on the road is when I lifted one side of the trailer when changing a flat tire there was sometimes a side link that would flip which can be a big problem on the road getting it back in the correct position.
Lifting the end of a axle was all that was needed. Eliminates flipped links.
senior moment...Wheel weight changed to 4600 axle weight...jim
* This post was edited 11/09/20 06:46pm by JIMNLIN *
rockwind1
las vegas
Posted: 11/09/20 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
ok, finally was able to take some pictures,, hopefully i can put them on here. the flat springs are the front axle, the curved spring is the middle axle,, the messed up looking rubber bumper is in between the front and middle axles, this bumper looks messed up as it was the one next to the flipped shackle, the other side looks fine. the tag is on the front axle, i am surprised it says 5200 lbs when the trailer tag says 5080. the equalizer is inbetween the front and middle axle and it says dexter 13-144
i think the equalizer may be stuck in that position,, it has not moved,, could be a problem,,,thoughts for anyone?
here is a youtube video of the pictures i took,,, could not upload them onto here
https://youtu.be/Rxj7Q1vqNfY
time2roll
Posted: 11/09/20 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Official RV.net upload site to create a photo link:
http://photoposting.is-great.net/?i=2
Your video:
That does not look quite like I expected. The equalizer bushings look shot. This may contribute to them out of position. Have you put a bar in there to make sure they are not frozen in place from corrosion or poor installation?
Looks like a Dexter equalizer and they did have some shipped with bad rubber. Probably no warranty at this point.
The geometry gets out of shape when the springs are elongated from being flat. the compressed rubber is not helping either. I think this is bunching up your equalizers and pushing them into a bad position. Long shot would be the equalizers are the wrong size between the springs.
Fully read the Dexter equalizer manual. Note there is a difference in equalizers for triple axles. Diagram p6 shows how it should lay out. I could not see all the angles needed in the video to really get a good picture of what is going on. You need to be your own expert on this.
Dexter ez flex manual
Get your tape measure out and verify the dimensions etc.
* This post was last edited 11/09/20 09:55pm by time2roll *   View edit history
GDS-3950BH
DC
Posted: 11/10/20 02:05am Link  |  Quote  |  Print  |  Notify Moderator
Tyler0215 wrote:
Why would you even consider a "Shady" repair shop?
Perhaps because its a lot cooler than a sunny repair shop?
rockwind1
las vegas
Posted: 11/10/20 10:47am Link  |  Quote  |  Print  |  Notify Moderator
so i rolled the front and rear axle up onto blocks about 3 or 4 inches high,, and the middle axle dropped down and made the equalizer move into a more neutral positon, here is video
i think it is clear the front leafs have weakened so much, probably from me driving with the trailer tilted forward ( i had no idea this was creating a problem) that it is messing with the equalizers and also that flipped shackle messed up the one bumper.
the question now remains, do i just buy a new pair of front leaf springs and a new bumper,,, or do i buy all new 3 pair of leafs and a front bumbper.
rockwind1
las vegas
here is new video
https://youtu.be/HKsM1k5WL_o
