RV.Net Open Roads Forum: Travel Trailers: Recommendation needed for first camper trailer
 > Recommendation needed for first camper trailer
Monterey, California
Posted: 11/05/20 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Still may not be under your payload. Which is?
Fisherman
Angus, Ontario, Canada
Posted: 11/05/20 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
I think that engine is a little on the anemic side for towning something at max load. On digging a bit, it appears that GM is letting it go in the direction of the dodo bird, looks like 2022 will be the last production year.
JIMNLIN
Oklahoma
Posted: 11/05/20 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Looking at chevy ordering guide shows the 2020 ZR2 has a 3200 RAWR and may weigh 2100-2000 lb on the rear axle leaving approx 1100-1200 lb payload on the rear axle. The ZR2 diesel take a big hit on towing performance.
Here is a BH from Allen Campers https://www.allencampermfg.com/upload/215%20BH%208.30.pdf that has a 5000 GVWR and dry is 3375 lbs with a 1625 CCC. Bought my first 8' then a 9.5' truck camper in '72 and '76 from them.
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 11/06/20 12:55am Link  |  Quote  |  Print  |  Notify Moderator
You could go with the smaller trailer, but for those of us who've been there or have seen this movie a few times, there's a 90% chance you'll regret it and want to move up to a bigger trailer in a year or so.
I know it's not my money, but consider trading out the ZR2 for a used 3/4 ton or a half-ton already set up for towing. Can't imagine either would be in short supply up in Idaho.
* This post was edited 11/06/20 08:00am by lane hog *
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
wowens79
Georgia
Posted: 11/06/20 03:40am Link  |  Quote  |  Print  |  Notify Moderator
Have you thought about a pop up?? We started in one, and loved it for the 9 years we had it. Easy to tow. Lots of windows. Ours had a king and queen size beds, and a futon, and dinette that converted to beds.
It’s different from what you’ve been looking at, but it’s worth considering.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
valhalla360
No paticular place.
Posted: 11/06/20 06:21am Link  |  Quote  |  Print  |  Notify Moderator
mcblake wrote:
ok, sounds like I will be over weight with that camper....
I have also looked at this one: Coachmen Apex Nano 194BHS, this one is about 3500 pounds and it checks all the boxes. Problem is I can not find any used (pretty sure its new in 2021). It's over my budget of 15k, any suggestion to keep me under that and my weight restrictions?
Didn't write down the models but I know we saw at least 2-3 models with a near identical layout while looking recently. Didn't write them down because they didn't meet our needs.
I would agree that if you aren't in love with the truck, swapping it would open up a lot of better options. If you get out on a rainy weekend, it's going to be really tight with 4 of you in that small of a trailer.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
deltabravo
Spokane, WA
Posted: 11/06/20 06:49am Link  |  Quote  |  Print  |  Notify Moderator
KD4UPL wrote:
I really thought the diesel Colorado had a higher tow rating than that.
The ZR2 model has a lower tow rating that the other Colorado models.
I had a Viking 17BH that would make a good TT for a Colorado. It had bunks, small fridge, bathroom with shower (but no sink) and a bed up front. I don't recall if it was a queen or full.
tomman58
Southeast Michigan
Posted: 11/06/20 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Agree with those that say you are not going to get the towing cap with that truck. Option pop up is about your only solution. This spring check out a camper show and refine your plans.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
rbpru
North Central Indiana
Posted: 11/06/20 09:13am Link  |  Quote  |  Print  |  Notify Moderator
If you do not know, rent a trailer.
We were unsure about the floor plan and length we wanted, so we took our best guess. We rented a floor plan we liked which dictated the length and headed for the Ozarks.
10 days on the road and we discovered, the floor plan was wrong and my 200 hp motor and 4 speed transmission would not work well. Who knew.
We did like the 25 foot length and the weight across the CAT scales did give us a useable tongue weight for the max cargo capacity.
Since then, we upgraded the truck and found a floor plan we liked. We have towed over 40,000 miles in 5 years.
Renting was a smart move, before we spent the big bucks.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
cekkk
Southern Nevada
Posted: 11/06/20 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Since you mentioned it's your first travel trailer, I'll tell you about my first travel trailer. I've made enough mistakes in my life to know that buying something for the first time is often problematic. So I went out looking for what I thought we would like, but used, and at a steal price. I found it, we towed it around a few thousand miles, put a few extras into it and sold it for precisely what we paid for it. All we lost was the electric tongue jack cost and the onboard EMS system. The camper we bought to replace it has been perfect for us for many years. Just something to consider.
'11 Eagle 320RLDS '02 Ford F350 DRW 7.3 PSD
"The world will not be destroyed by those who do evil, but by those who watch and do nothing" - Albert Einstein."
