showme
Park Hills, MO
We bought an older Montana 5th wheel (2000) 2 years ago to set up at the property we're going to build on. Got it mainly as a break trailer to get out of the weather while we work on the land (43 acres), and to store our expensive tools in while we're not there.
I noticed early on that the old antenna was gone when I saw the whole in the bedroom ceiling with no handle or hardware, which is not a problem. It doesn't leak, as far I've been able to tell, but I got up on the roof the other day to sweep off the pine needles that had accumulated from where we had it setting until a few weeks ago. Up on the roof, I noticed that there's no cap or anything on the hole where the antenna formerly was. I'd really like to cap and seal it, but I'm not having any luck finding a simple white cap to cover it with. I've found youtube videos of everything from cutting aluminum sheet and screwing/sealing it, but that looked terrible. (I know, who's going to see it, anyway?)to patching over it with epdm rubber. All it needs is a simple cap of some sort, which would serve the purpose, look decent and be an easy fix. Does anyone know where to find something like this? Thanks, Lee Butcher
garyp4951
TN
Look at hardware store for stool, or crutch rubber tips, and use Dicor self leveling caulk on it.
If its level use eternabond tape.
Sjm9911
New Jersey
Use both!
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
94-D2
Sutter Creek ca
Try a plumbing vent cap. Simple sealed.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
It’s not what you’ve done that commands respect, it’s what you do.
Happy Campin’
bucky
Raleigh metro
They make round white home door knob protectors now. Any ace or big box will have them. Bed of dicor around the edges and you are gold.
clicky
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
cavie
White eternabond tape.
Veebyes
Something simple like a piece of formica sealed down would do the trick. Inside I would put up a nicely varnished piece of wood to cover the hole. Does nothing but looks better than trying to match whatever the ceiling covering is.
2007 Alpenlite 34RLR
K Charles
Connecticut
You could get an antenna for about $100, and that wouldn't look bad.
near Bishop, California
I'm for a plug, tape and Dicor/Heng's.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
joelc
Cedar Point, NC
I would 1st use Fiberglass resin to fill the hole and trowel smooth and then cover it with eternabond tape, using dicor on the edges to seal.
