RV.Net Open Roads Forum: Class A Motorhomes: no high beam headlights
 > no high beam headlights
Tom/Barb
Oak Harbor, Wa
Posted: 11/06/20 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Things we have already done.
1 changed both headlights, confirmed with continuity check.
2 replaced headlight switch. still no high beams.
3 replaced the relay (part number - H8002B).
4 checked every fuse in the coach. (continuity confirmed)
5. checked for power at the relay in both directions. power is good.
2000 Newmar mountain aire.
low beams work, as well as parking lights as well as the dash dimmer.
suggestions ?
enblethen
Moses Lake, WA
Posted: 11/06/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Am guessing you have a multi-function turn signal switch assembly. Have you checked for control voltage to the high beam relay? Does your turn signal lever allow for pulling up for energizing the high beams and down to lock in high beams?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Charley67
Fulton, MS
Posted: 11/06/20 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
I just resolved a problem with no low beams. I was about to go into the steering column and look at my multifunctional switch, but I saw that my headlights relay was the same as one right beside it, so I switched them and bingo, lights working bright and dim. $21 at parts store and all is well. Good luck.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 11/06/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a smart steering wheel?
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
Tom/Barb
Oak Harbor, Wa
Posted: 11/06/20 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
yes.
Tom/Barb
Oak Harbor, Wa
Posted: 11/06/20 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
The signal light lever can move 3 ways, left/right/ up.
the left/ right turn lights work normally.
the UP is supposed to cause the high beam to come on or off as required. it does nothing. high beams never come on.
I all so notice the the panel lights that operate dim bright function (dimmer) is always on when the key is on.
the light switch also operates the Over head reading light. it operates normal.
also the low beam lights are alway on when the key is on.
Tom/Barb
Oak Harbor, Wa
Posted: 11/06/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
there are two headlight relays, 1 was not working. I replaced it. still no high beams.
I switched it, no difference - still no high beams.
enblethen
Moses Lake, WA
Posted: 11/06/20 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check for control power at the relay coil? Other side of coil should be ground.
Jumper the contact point in the relay socket to see if high beams come on.
* This post was edited 11/06/20 06:43pm by enblethen *
Tom/Barb
Oak Harbor, Wa
Posted: 11/06/20 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
YES, there is no voltage there. relay is good.
some thing has the circuit to the high beams turned off.
next question? is the low beams suppose to be on with the key on. head switch fully pushed in
I've never noticed.
enblethen
Moses Lake, WA
Posted: 11/06/20 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Low beams on some vehicles are daylight running lights.
Don't know if your rig is equipped in that way.
