RV.Net Open Roads Forum: Class A Motorhomes: no high beam headlights
 > no high beam headlights
enblethen
Moses Lake, WA
Posted: 11/06/20 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
In theory the low beam relay would be energized by the ignition switch. Low beams would go out when high beams come on.
A set of contacts in the low beam relay could be bad if my theory of operation is correct.
If low beam relay is the same as high beam or if you have old relay, change out low beam relay.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tom/Barb
Oak Harbor, Wa
Posted: 11/06/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Up date..
as soon as the key is turned on, the low beams come on. headlight switch fully retracted.
headlight switch out 1 click, low beams still on.
headlight switch full out (2) clicks, all lights go out.
is there a chance a relay is out of position.
nc19143@comcast.net - for pictures of the fuse boxes and relay position.
Tom/Barb
Oak Harbor, Wa
Posted: 11/06/20 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
we will do that in the morning.
enblethen
Moses Lake, WA
Posted: 11/06/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
First click should be parking lights, second should be headlights.
Post relay and headlight part numbers.
AllegroD
Outdare
Posted: 11/06/20 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
Had a similar problem a few years back. Brights but no dims. Turned out to be the wire harness in the column.
Tom/Barb
Oak Harbor, Wa
Posted: 11/07/20 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Right .....
did it again same results, all relays checked aging. all fuses checked again....
relay part number is 12088570
enblethen
Moses Lake, WA
Posted: 11/07/20 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Sure sounds like it is the multi-function switch in the steering column or the wiring between it and the relay.
Is your relay and wiring in the compartment on outside below the driver?
Tom/Barb
Oak Harbor, Wa
Posted: 11/07/20 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
It's in the front cap.
what is powering up the low beam head lights when the switch is off?
enblethen
Moses Lake, WA
Posted: 11/07/20 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
My guess it is from an ignition circuit.
You never noticed before that the headlights were on all the time? Did you have critters get in the rig and eat wiring?
Are the relays plug-in style? Pull the low beam relay and see if they still lit.
Have you tried to look for wiring diagram on Newmar's website?
Newmar
Tom/Barb
Oak Harbor, Wa
Posted: 11/07/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Newmar
I'll get Newmar involved Monday.. they don't work Fridays.
