RV.Net Open Roads Forum: Class A Motorhomes: no high beam headlights
 > no high beam headlights
enblethen
Moses Lake, WA
Posted: 11/07/20 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
You might try set up the account login. It could be interactive to some point.
Memory says Newmar uses their own chassis, is that correct?
Do you have the Owner's manual. Is there anything in it about chassis operation?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tom/Barb
Oak Harbor, Wa
Posted: 11/08/20 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
re-Checked the install of the headlight switch. every thing is good.
symptoms--
as soon as the ignition switch is turned on, the low beams turn on.
all relays are checked and operate properly. all fuses in the entire has been tested.
Tom/Barb
Oak Harbor, Wa
Posted: 11/10/20 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Tom/Barb wrote:
enblethen wrote:
My guess it is from an ignition circuit.
You never noticed before that the headlights were on all the time? Did you have critters get in the rig and eat wiring?
Are the relays plug-in style? Pull the low beam relay and see if they still lit.
Have you tried to look for wiring diagram on Newmar's website?
Newmar
I'll get Newmar involved Monday.. they don't work Fridays.
Well that doesn't work either.
spent 2 days trying to get NEWMAR to answer the phone, that doesn't work, so I sent them e-mail, the answer was to have Newmar send them a e-mail. so I set waiting for a call back.
getting parts? right a way, service not so much.
Tom/Barb
Oak Harbor, Wa
Posted: 11/10/20 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Reading about " Smart wheel " and find that nothing on the wheel works.
reading more..
enblethen
Moses Lake, WA
Posted: 11/10/20 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I heard that Newmar had good customer support. Guess that is a myth!
Have you seen this for smart steering wheel.
Smart wheel
Tom/Barb
Oak Harbor, Wa
Posted: 11/10/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Smart wheel
Yes we have, your the second person to link us in
So, we are doing the trouble shooting as we can.
verified the box is toast.
and they are back ordered,, So we are trying to get a check and test /repair/by the company.
OBTW,, Newmar gave us new Phone numbers. Apparently the phone tree doesn't work.
enblethen
Moses Lake, WA
Posted: 11/11/20 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
You might to check with Colaw they have both salvaged and new parts.
Tom/Barb
Oak Harbor, Wa
Posted: 11/11/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
New one on order at https://www.vipwheels.com/
$ 200.00
enblethen
Moses Lake, WA
Posted: 11/11/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Keep us posted on results!
Tom/Barb
Oak Harbor, Wa
Posted: 11/11/20 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
we will
