RV.Net Open Roads Forum: General RVing Issues: Beware Camco Water Heater Tank Rinser
 > Beware Camco Water Heater Tank Rinser
chuckbear
Posted: 11/08/20 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I bought one of these to clean my hot Water tank. Five seconds after I started, the long tube blew off inside the water heater where it now permanently resides. I don't know what this means for the future of the water heater but would advise others to use extreme caution in using this poorly designed and manufactured device. Chuck
bukhrn
Lanexa, Va
Posted: 11/08/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Try one of these, you'll have to be extremely patient & lucky, but it beats leaving that thing in there.
https://images.search.yahoo.com/search/i........737371878-0-1%2Fs-l1000.jpg&action=click
2007 Forester 2941DS
2014 Ford Focus
Old-Biscuit
Verde Valley
Posted: 11/08/20 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Had one of those Camco Water Filler that you attach to your hose then stick down into gravity port to fill fresh water tank
Second time I used it the Tube blew off.....been inside my fresh water tank since 2008
Plastic tube inside your Water Heater????
I can see several issues:
Getting hung up on one of the Dip Tubes
Banging around breaking one of the DIP Tubes
Getting stuck in drain hole and blocking draining of tank
If Suburban ....easy to remove the electric element and give you larger hole to retrieve it from
Same if Atwood ...access not as easy due to element being installed from backside of tank
Either way....I would remove it
CAMCO......CHEAP, JUNK and I refuse to purcahse anything from CAMCO
HINT:
In further to flush water heater
Turn water supply off
Relive System Pressure...open faucet hotside
Remove drain plug
Turn Water Supply ON...FULL
Stand back and let it BLAST out the drain hole
*Cold inlet dip tube points downward and will stir up sediment on bottom of tank
capacitor
California
Posted: 11/08/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the tip, I just bought one. I hope you get it out.
chuckbear
Posted: 11/08/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I have ordered one of these. Hope it does the job. Chuck
bukhrn
Lanexa, Va
Posted: 11/08/20 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Good Luck, just remember, it's like fishing in the dark, and if it doesn't work, it's always handy around the house for other things.
opnspaces
San Diego Ca
Posted: 11/08/20 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I would ignore it. it's a plastic tube it's not going to hurt anything.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Learjet
Louisiana
Posted: 11/08/20 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
just leave the plug out, turn on water and plastic piece should work its way to the hole...then grab with some needle nose pliers.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
Old-Biscuit
Verde Valley
Posted: 11/08/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
If Atwood drain hole is only 1/2" opening...may be too small to use grabber and pull tube out
Suburban has 3/4" drain hole and MIGHT be able to use grabber
Personally I would remove element ...1" Opening
Plastic....Suburban WH it could get stuck between combustion/exhaust 'U' tube which is STACKED on top of each other.
Plastic up against combustion/exhaust 'U' Tube can melt
Less chance with Atwood due to diagonal 'U' Tube...
Water temps could reach 170*/180*F if T-STAT Fails which could make that cheap plastic very soft/pliable (heck 130*/140*F might also...don't know temp rating of that cheap plastic)
Remove it...be done with it....why leave it to cause problems
wanderingbob
monticeeo, fla
Posted: 11/08/20 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Why do ya feel the need to rinse your water heater ? Do you rinse the one in your house ?
