RV.Net Open Roads Forum: Class C Motorhomes: house batteries and generator
 > house batteries and generator
mct1234
sc
Posted: 11/08/20 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
My RV will not be used for several months. I want to take the house batteries out and put them on a trickle charger in my house. But I also normally drive the RV every 2 weeks or put a trickle charger on the engine battery, and run the generator for an hour once a month to keep the engine battery and generator running.
Can you run the generator without the house batteries ? Are they necessary to start the generator?
bobndot
Posted: 11/08/20 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Usually the house battery but some rv's use the chassis.
Seems kind of easy to find out. Without being plugged into shore power, why not remove the cables from the house battery and try to start the generator ?
You might have options:
Do you have shore power 24/hrs where you park it ? Leave it plugged in if you have a multi stage converter . Some systems like mine use the converter to charge the house and chassis batteries. My solar panel also charges both banks as well . Use a multi meter to test your system to see if they both charge.
June Lake area, California
Posted: 11/08/20 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Solar panels with a good controller is the easy way.
ksg5000
Oregon
Posted: 11/08/20 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on how your rig is wired. Easy to test - remove the battery and try and start the Generator. If you park your rig near a electric outlet you should just plug it in - most modern converters will maintain your battery without harming it - add in an inexpensive Trik L Charger and your converter will keep your chassis battery charged as well.
Kevin
KD4UPL
Swoope, VA
Posted: 11/08/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
If your going to drive it every 2 weeks and run the generator once a month why would you want to go to the trouble of removing the house batteries? If you leave them disconnected when the RV is no in use they should stay plenty charged up for the 2 weeks the RV is not driven.
Posted: 11/08/20 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
^This.
Or slap a solar charger on the whole thing and fire it up next spring. You’re in SC. Not hard on batteries in the winter.
2017 Heartland Torque T29
kane8907
East Brunswick,NJ
Posted: 11/09/20 01:06am Link  |  Quote  |  Print  |  Notify Moderator
Should it remove the batteries to prevent car stealing?
valhalla360
No paticular place.
Posted: 11/09/20 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Here's your answer...save a whole lot of hassle if you are going to drive it and run the generator anyway. Just make sure to disconnect the batteries when you are done and they should easily hold up for 2 weeks.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
pnichols
The Other California
Posted: 11/09/20 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm ... if it were me, I'd move to a place where people don't steal cars. [emoticon]
Phil, 2005 E450 Itasca Spirit 24V
valhalla360
No paticular place.
Posted: 11/09/20 10:52am Link  |  Quote  |  Print  |  Notify Moderator
A hidden battery disconnect switch would be a lot easier than pulling both battery banks.
