RV.Net Open Roads Forum: Towing: Tranny overheated
Search only in Towing
Open Roads Forum  >  Towing
 > Tranny overheated
Page of 6
dodge guy
Bartlett IL
Posted: 11/12/20 05:42am Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing they put a valve bidy in it. Those have the computer built into it and need to be programmed. Yes they take about 7 qts and is more than enough for a fluid change. I say do the next fluid change at 50k miles.
* This post was edited 11/14/20 09:21am by an administrator/moderator *
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
rhagfo
Portland, OR
Posted: 11/12/20 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Well May I say it is time you dig into your owners manual, and understand the Information Center. I can see digital engine coolant, transmission fluid, and engine oil temperatures, along oil pressure is one screen below the digital speedometer. This menu is accessed simply by pressing the down arrow on the left spoke of the steering wheel.
goducks10
There
Posted: 11/12/20 09:46am Link  |  Quote  |  Print  |  Notify Moderator
X2.
Posted: 11/12/20 11:17am Link  |  Quote  |  Print  |  Notify Moderator
If it didn't actually overheat and it was just an electronic issue, then a pan drop and replacing half the fluid is fine.
If it did overheat, I'd want to see the fluid, at a minimum, which I'm guessing you didn't check. And regardless, I'd do a complete fluid replacement.
kfp673
PA
Posted: 11/12/20 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Of these things you list trans fluid temp is the one I don't currently have showing. I have my trailer break gauge showing instead but I will add it for sure. That said, the overheat did not happen until long after that limp mode kicked in so not sure what it would have done for me, but I guess it's nice to see if it is creeping up in temp.
goducks10
There
Posted: 11/12/20 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
You are correct in that your temps were rising but you didn't know it. Had you had the page with the engine, trans and oil temps and oil psi on, you should've been able to watch the temps rise.
My trans temps run around 168-172 under all normal driving and towing conditions. Only when I get to a steeper grade and it's warm to hot out does the trans temp rise. If my trans temp hit 180+ and I was under normal conditions that would've been a sign that somethings not right.
Anyway nice to see your dealer is getting it fixed.
pitch
NY
Posted: 11/13/20 06:50am Link  |  Quote  |  Print  |  Notify Moderator
My '13 Ram 1500 runs approximately 80 degrees above ambient.
* This post was edited 11/14/20 09:20am by an administrator/moderator *
goducks10
There
Posted: 11/13/20 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Thats a lot of variance. So at 40* your trans temp is 120 and at 90* your trans temp is 170?
* This post was edited 11/14/20 09:18am by an administrator/moderator *
pitch
NY
Posted: 11/14/20 07:35am Link  |  Quote  |  Print  |  Notify Moderator
yes
campigloo
Baton Rouge, La
Posted: 11/15/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Also keep in mind the only thing a trans flush flushes is your wallet. Just have a proper fluid and filter change
Page of 6
 > Tranny overheated
