dodge guy
Bartlett IL
campigloo wrote: Also keep in mind the only thing a trans flush flushes is your wallet. Just have a proper fluid and filter change
With regular fluid changes yes, that's all you need. If not that a trans flush will flush near 100% of the fluid out of the trans. When I do it at work I don't use any cleaners or additives. Just the correct fluid. Clean goes in and sold fluid comes out.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
deltabravo
Spokane, WA
kfp673 wrote: I have my trailer break gauge
Which trim level trucks have a gauge to show a broken trailer?
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20, sold 7/28/20)
trail-explorer
NM
deltabravo wrote: kfp673 wrote: I have my trailer break gauge
I think it's the PlatinumBigHornLaramieDenaliLTZ model
Bob
kellem
Shenandoah valley,VA
I can tell you from experience that tranny temps should be monitored while towing in the big hills.
175* - 220* is the safe zone.
240* varnish starts to form and higher, seals harden.
Was towing in the mountains in WV and saw 265* on my Chevy avalanche before I could Crest the hill and lost the transmission a week later sitting in the parking lot of Petsmart.
All my trucks get auxiliary coolers now if not already equipped.
afidel
Cleveland
ACZL wrote: Tho I have a Ford, I'm w/ dodgeguy on changing tranny oil every 25-30k. Likewise, I still drop oil every 5k as well Like DG said, "Oil is cheaper than........"
On a side note, this thought came to mind as I was reading the updates and suggestions and all. Why can't mfr's design the software to have the engine fan come on (even tho water temp is ok) if a sensor is telling the computer something is getting hot and to draw more air thru to try and cool things down?
Huh, I'm doing oil every 5k and just did the tranny at 45k miles, I'm following the severe duty schedule in the manual. I do watch my temps and even when climbing the Beartooth mountains I've never been in the danger zone on tranny temps. Now you're making me wish I had asked the shop to grab a retain to send off to a lab.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
This entire thread makes me wish I kept my 6 speed row yer own truck!
Lol
rhagfo
Portland, OR
dodge guy wrote: campigloo wrote: Also keep in mind the only thing a trans flush flushes is your wallet. Just have a proper fluid and filter change
I have done full fluid changes in the past on our 1989 F250 460, with C6 trans. The cooler return line just dumped into the pan.
Took a bit of fluid, but once the pan and filter had been removed and replaced, you added enough to fill the pan. Then disconnect the return line with a big catch pan under it, start the engine, while helper ran the trans through the gears, you added fluid while watching the fluid coming out of the return line. When it changes from dark red to bright red stop the engine and reconnect the return line. Check the fluid level and top off.
I don't know if you can do that on current transmissions.
kellem
rhagfo wrote: dodge guy wrote: campigloo wrote: Also keep in mind the only thing a trans flush flushes is your wallet. Just have a proper fluid and filter change
That's precisely the way I've done it for years with wife in vehicle.
NOTE:
You'll know quickly if you've disconnected wrong line apon start up, instant mess.
Cheap insurance? I totally believe in proper maintenance. From personal vehicles to managing or maintaining fleets.
But there is zero “cheap insurance” by performing maintenance significantly ahead of the required or suggested intervals.
I mean, I’m more likely to buy a used vehicle from someone’s Grampa who changed the oil every 3000 miles. But it only shows anecdotally that he may have cared for the rig overall better. There’s no extra residual value. So hypothetically, “if” one was planning to keep the vehicle for 300k or 500k miles, there “might” be a slight decrease in wear, but at that point, who cares? Because the normally maintained vehicle will statistically last just as long.
frankwp
Calgary, AB, Canada
Grit dog wrote: Cheap insurance? I totally believe in proper maintenance. From personal vehicles to managing or maintaining fleets.
Research on the subject I've read shows, for example, that oil additives are present and doing their job well past the manufacturer's recommended interval. There is just no upside to more frequent maintenance other than the piece of mind it may give. To some, that's worth the added cost.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
