RV.Net Open Roads Forum: Tow Vehicles: Pulling Travel Trailer in Colorado with Tahoe
Search only in Tow Vehicles
 > Pulling Travel Trailer in Colorado with Tahoe
dcrawdad29
St. Louis, Missouri
Posted: 06/26/21 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I finished the trip. I made base camps at Golden Gate Canyon State Park Campground (Reverend's Ridge...beautiful fyi) and KOA Colorado Springs. I give the 2008 Tahoe a "C" for the trip. It definitely had the power, but transmission temps were the enemy. In Colorado, the max temp I saw was 221 on 2 occasions but max time above 220 was 3-4 minutes all trip. I hit 221 at the top of the Golden Gate Canyon Road and once simply driving from Golden Gate Canyon State Park to Colorado Springs. I had to pull over past Denver to allow some cool down. Colorado was unseasonably warm this summer when we were there. Outside temps 95 degrees and above and if I got a series of inclines with not enough declines or flat runs in between, it would continue to rise with that amount of outside heat in the air. Coming across Kansas it was really hot too and if I ran the a/c, the temps would go above 210. I got to 216 before I realized that if I cut the a/c, then the transmission temps would range mostly between 198-205. So, we went without a/c for much of the trip. If outside temps were 85 degrees and below though, my trans temps improved even further (upper 180s and 190s). I did add an aux trans cooler and I cannot imagine having taken the trip without it. It was a must have. While I did take a day trip to Glenwood Springs, I did it without the trailer and I am happy I was not towing after I saw what Vail Pass was about. The most difficult part of the trip for me though was dealing with the wind in Kansas. I ran mostly 60-65 mph vs. the speed limit of 75 mph as a result.
cekkk
Southern Nevada
Posted: 07/17/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Having lived and towed in Colorado's mountains with a proper TV, I shake my head reading threads like this. Engine was great but the transmission...Surprise! Virtually no mention of brakes, suspensions, wheel base, payload. The fact that most of them get home alive is Testament to the quality today's automobiles.
'11 Eagle 320RLDS '02 Ford F350 DRW 7.3 PSD
"The world will not be destroyed by those who do evil, but by those who watch and do nothing" - Albert Einstein."
dcrawdad29
St. Louis, Missouri
Posted: 07/18/21 06:47am Link  |  Quote  |  Print  |  Notify Moderator
I had new brakes and rotors put on tow vehicle just before trip. I also had trailer brakes adjusted prior to trip. I used down shifting throughout the trip on declines. Tongue weight and payload was under the limit for tow vehicle. Also I used a weight distribution hitch. My wheel base was within range for tow vehicle dimensions. Happier now?
Posted: 07/19/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the feller had a good trip and a very informational report on what his rig will do. This is the best info that can be posted to help others.
And he kept everything in one piece and why does this bother you?
2017 Heartland Torque T29
