dougrainer
Carrolton, Texas
NC6B wrote: Tom/Barb wrote: I'd have a auto glass company remove the glass and clean all of the old sealer off and see if the glass fits properly.
you will have to remove it anyway, give it a try. I was told by the tech, "if they remove the windshield it will break".
Yes, in most cases, pulling a CORRECTLY SEALED and installed Windshield may break when removing. Since they failed to correctly seal/adhere the Glass, I doubt it will break. An Attorney will cost MORE than just paying for a new windshield. Your best bet is to have a good Shop remove and reinstall or if it breaks, install new glass. Then sue in small claims court for the cost of the correct repair. Also, contac your RV Insurance company to see if your coverage will pay for a new windshield. Doug
N6WT
Huasna Valley, CA
dougrainer wrote: NC6B wrote: Tom/Barb wrote: I'd have a auto glass company remove the glass and clean all of the old sealer off and see if the glass fits properly.
Yes, in most cases, pulling a CORRECTLY SEALED and installed Windshield may break when removing. Since they failed to correctly seal/adhere the Glass, I doubt it will break. An Attorney will cost MORE than just paying for a new windshield. Your best bet is to have a good Shop remove and reinstall or if it breaks, install new glass. Then sue in small claims court for the cost of the correct repair. Also, contac your RV Insurance company to see if your coverage will pay for a new windshield. Doug Doug
Thanks for this suggestion.
I have had an idea that I got from noteven. I will do an air pressure test. I can seal the area around the top of the windshield with heavy plastic I have. Then I will hook up my shop vac to blow air into it. I will then put soapy water on the outside to see if there are any leaks.
Kent
N6WT
oldave
Tx
Sometimes they use a blower like you may have seen to dry carpet or you can use a blower out of a home heating & air cond unit. The blower can be made to blow
through a window or door that is sealed with plastic, cardboard, etc
Tom/Barb
Oak Harbor, Wa
you will have to remove it anyway, give it a try. I was told by the tech, "if they remove the windshield it will break". n
normal method to get the glass out is to break it..
you don't have to break it.
noteven
Turtle Island
NC6B wrote: The latest on this.
I received a phone call from the glass company. They are going to blame the running lights. Even though when I put water on the windshield I make sure no water gets on the lights. I am looking for an attorney now and I am going to reseal the lights.
Kent
N6WT
Pressurize the interior with a fan and find the leak with soapy water.
N6WT
Huasna Valley, CA
noteven wrote: NC6B wrote: The latest on this.
Kent
N6WT
Pressurize the interior with a fan and find the leak with soapy water. I tried yesterday and could not get any positive results. Thanks!
Kent
N6WT
N6WT
Huasna Valley, CA
I have had enough with this. I am working on a deadline. My wife and I will be moving into the motorhome in a few weeks while we are doing an 8 month remodel on our home. I need to get this done.
I called another glass place and they said they would do a water test. I'm taking it to them next week. If I have to take the windshield out and it breaks I'm going to send the other company the bill.
Kent
N6WT
2015 Newmar Ventana 4002
2003 Jeep Rubicon O||||O
UPS Feeder Driver retiring in July 2016!
Ham call sign was NC6B now N6WT
Gjac
Milford, CT
I may have missed something in this thread, but in my state the insurance company is required to replace cracked windshields free of charge. I have had 3 windshields replaced since owning the MH and there were no deductible or any other charges to pay. One leaked while on a trip after having it replaced at home and another company in TN. fixed the leak. I had to call the insurance company and go to one of their recommended facilities to have it covered.
N6WT
Huasna Valley, CA
Gjac wrote: I may have missed something in this thread, but in my state the insurance company is required to replace cracked windshields free of charge. I have had 3 windshields replaced since owning the MH and there were no deductible or any other charges to pay. One leaked while on a trip after having it replaced at home and another company in TN. fixed the leak. I had to call the insurance company and go to one of their recommended facilities to have it covered. I have not heard of this. However I have a different insurance company from 2017. Never the less I will call my insurance agent and see what they can do.
Thanks
Kent
N6WT
oldave
Tx
Here in Tx, I think it was that way or maybe the glass co just forgave the $50 deductible
But on the last windshield, they charged me the $50 saying it is required now.
I don't know if it is actually a law or just something the glass & insurance companies started doing. The girl in the office didn't know, didn't care either
