RV.Net Open Roads Forum: Generator for full time use in destination trailer.
 > Generator for full time use in destination trailer.
JSWa
Snohomish
Posted: 11/11/20 12:34am Link  |  Quote  |  Print  |  Notify Moderator
I am going to live in my destination trailer full time (3-6 months) while my house is built. What type of generator should I use? Does not need to be "portable". I will be using a lot of power as I have computers, gaming systems, extra freezer and refrigerator for outside (chest type). Need to be able to run some home grade power tools at same time as everything else. Must be able to run non stop for 6 months +. I would rather go slightly overkill on this because it's pretty important that I have enough power and it be reliable.
50 amp trailer.
Will have a large new shed next to the trailer, so I can store it out of the weather if necessary.
I have never lived in a trailer or owned any type of generator.
DrewE
Vermont
Posted: 11/11/20 01:55am Link  |  Quote  |  Print  |  Notify Moderator
Will your house have electric service? Assuming so, get a temporary construction drop/panel and use that to power your trailer, etc. while building.
If you absolutely must run a generator (nearly) constantly for six months, give careful consideration to what fuel is available and least expensive where you are. You'll use a considerable amount, probably a few thousand gallons if gasoline or diesel, or the equivalent in propane or natural gas. Installing a solar setup may well be less expensive and definitely would be less noisy and smelly; and with that you'd probably just need a small backup generator (maybe 2000 watts or so) to keep the fridge and freezer going in case there are several cloudy days in a row.
Wherever I happen to park
Posted: 11/11/20 03:24am Link  |  Quote  |  Print  |  Notify Moderator
I would give serious consideration to a SOLAR system as well as a good generator. NO it does not need to be a portable.
Most houses (Absent air conditioner) can get by on 5,000 watts of power for Furnace, lights, electronics and kitchen (The services you need) You might consider having an "Whole house" emergence generator Generac or Onan installed in the say 10,000 watt range (this will run most A/C's too)
then when the house is wired you put in two breaker panels. One is "Mains only" and the other.. is the "E" panel (Emergency) that way when (not if) the power company lets you down the back up kicks in
Home is where I park it.
craig7h
Branson MO area
Posted: 11/11/20 03:27am Link  |  Quote  |  Print  |  Notify Moderator
For what you are talking about, I would go along with what Drew said about the temp electric at the build site. That for many reasons makes more sense.
If a generator is a must, for that long of a period of time, I would call the "Generic" folks. You might as well go big and get something to use as back up for the house. Will your house have propane or natural gas? See if either company can run a temp line for the Generic while you are building. With that said I would try and do the temp electric service. Much easier and maybe safer.
Itasca Meridian SE 36g
Road Master Tow Dolly
Dave H M
IL
Posted: 11/11/20 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Drew has the answer. That is exactly what I did from 15 March until just before turkey day.
Bumpyroad
Virginia
Posted: 11/11/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
IIRC in VA if you get a builder's permit, the electric co will wire the lot up?
bumpy
deltabravo
Spokane, WA
Posted: 11/11/20 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Ditto.
When new houses are being built, this is how the construction crew gets power.
A temporary power service will be far cheaper in the long run.
A good generator for running full time and not be noisy as heck would be a Honda EU7000is.
For full time usage, I wouldn't want anything other than an inverter style gen.
I love my Honda EU6500is which was the predecessor to the 7000
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
theoldwizard1
SE MI
Posted: 11/11/20 07:23am Link  |  Quote  |  Print  |  Notify Moderator
By far the best solution !
This is a HUGE issue !
valhalla360
No paticular place.
Posted: 11/11/20 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for a temporary electric drop.
- Most retail generators are not rated for full time continuous use to start with. Plus they typically call for oil changes every 50-100hrs, which means you will have to do 2-4 oil changes per week and constantly be keeping it fueled up (at significant cost).
- A solar system that can run all the stuff you are talking about will be very large and very expensive (think 5 figures). It will also need a battery backup system capable of carrying you through the night.
PS: check with local zoning laws to make sure you can "live" in your RV while building. Many areas do not approve.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
bgum
South Louisiana
Posted: 11/11/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
If you must run a generator look into a military surplus generator skid mounted or trailer mounted. It will be diesel powered. Fuel will be expensive.
