RV.Net Open Roads Forum: Class A Motorhomes: 2000 Safari Sahara Slide out inop
 > 2000 Safari Sahara Slide out inop
map40
Posted: 11/11/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Hi guys! So, new to me Sahara has the main slideout stuck open and it won't close. I took the cylinder out to move it, but I have no idea how to troubleshoot it. Anybody knows where is the pump? Normal failure modes? Any help will be greatly appreciated!
Alfa SeeYa, 2015 Jayco XL31, 2015 Itasca XL31, 2012 CA 25, 2008 CA 28. RV with most millage: 312K miles on a V10
Life rocks when your home rolls
tropical36
Southwest Florida_USA
Posted: 11/11/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
So hydraulic, rather than Power Gear Electric. Can't help much, this being the case, but do wish to follow towards a solution, where others should be able to help you.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
map40
Posted: 11/11/20 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah. See, first time with hydraulic. The others I can take them apart like those wiz kids with the Rubik’s cubes. This sucker I can’t even find the pump! The hoses go into the frame and is all enclosed...
Bishop area, California
Posted: 11/11/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Does the owner’s manual give any information?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
map40
Posted: 11/12/20 06:19am Link  |  Quote  |  Print  |  Notify Moderator
To call customer service. Safari went under in 2001, Monaco picked it up and they went under. Nobody to call...
wolfe10
Posted: 11/12/20 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I hesitate to go on any forum and recommend another one. But, it is probably warranted in this case.
For more Safari-specific information you might try here:https://safarifriends.org/index.php
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
map40
Posted: 11/12/20 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I got it fixed. A fuse be the selenoid rusted out.
MrWizard
Traveling
Posted: 11/13/20 12:22am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the follow up
Keeping us know the fix
But did you find the pump?
Does it use the same hyd pump as the levelling jacks
Radiate The Happy
1997 F53 Bounder 36s
map40
Posted: 11/18/20 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
OK, so, it used the same pump as the 3 jacks, but somebody added an on-line fuse that was not documented. Reattached the cylinder (which was a PAIN), and the slideout started working.
Also, the solenoids were on the other side of the pump. On one side you had the jacks, while on the other side you had the slide out. If you didn't know any better, it could have been 2 different pumps.
The fuse was a 5 amp and fed the solenoid that activated the pump.
Slide works like a charm. Thanks.
