RV.Net Open Roads Forum: Travel Trailers: Propane Tanks Direction
 > Propane Tanks Direction
NRALIFR
Truck Camping Out West
Posted: 11/13/20 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Well that’s interesting. Honestly, since so many trailer propane cylinders seem to be covered these days, I wouldn’t know which direction most of them face anymore. Back when they were uncovered, I don’t think I ever saw any not facing forwards.
As far as the cover being required, I thought I remembered reading that somewhere. Maybe a NFPA or NPGA publication.
If it’s common now to face the cylinders so that the regulator is close to the trailer, that might explain why there seems to be so much pushback to using the auto-switch regulators with both valves open. If you make checking the indicator difficult, it’s probably not going to be checked very often.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
K_and_I
North Central Ohio
Posted: 11/13/20 08:00am Link  |  Quote  |  Print  |  Notify Moderator
My cylinders face forward, but the cover comes off hard as I have added batteries and the battery boxes come too close to the propane cover. I like to check which cylinder is being used without having to take the cover off, so I keep a small camping mirror in the front pass through so I can see the regulator through the top lid. Might work for back facing cylinders, too.
K_and_I
2011 Rockwood 2604
Nights Camped in 2019: 85
Do we have time for shortcuts?
wing_zealot
East of the Mississippi
Posted: 11/13/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
I switched mine around. What good is an auto changeover if I can't see what is going on.
BarabooBob
Baraboo, WI
Posted: 11/13/20 10:45am Link  |  Quote  |  Print  |  Notify Moderator
My automatic switchover regulator is mounted on the front of the TT with the tank outlet facing the TT also. It allows for a shorter hose and I can see which tank the regulator is drawing gas from and when a tank is empty. My tanks are both on because that is why I bought the auto switch regulator. Why have the regulator is the second tank is turned off.
Before pulling out EVERY DAY we do a pre-trip inspection of the TT. We BOTH check the hitch, safety chains, electrical hook-ups, LP tanks, awning, access doors, tires, entry door locks, 120 volt cord, sewage drains. refrigerator, etc. It takes us about 5 minutes but it gets done every morning. We have over the years, we have found something that could cause problems while on the way. We also pick up every scrap of litter from our campsite before we pull away. My kids also follow the same routine.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Boomerweps
Hills of PA
Posted: 11/13/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
It seems single tanks are rarely covered. Dual 20s & 30s usually are. Hard covers are made for single 20, dual 20, and dual 30. Soft covers can had for most all. I swapped out my single 20 for a single 30 to avoid the hassle & cost of mounting a new dual mount and gas hardware. Searched and searched for a single 30 hard cover, no joy.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
mobeewan
Hampton, Va
Posted: 11/13/20 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Seon wrote:
I have 40lb tanks without cover because there aren't any made if they are made, somebody plz provide a link.
I had thought of going from 30 to 40 lb cylinders and looked, but never found any hard covers, only soft covers. I wound up buying 2 more 30 lb cylinders instead.
I have seen where someone made one out of 2 separate covers. They trimmed the bottom portion off of one and cut the top portion off the other and pop riveted them together where they left an area that overlapped. You just have to make sure you pop rivet from the inside around the area that touches the cylinders. Maybe add a piece of eternabond on each rivit head so it doesn't rub on the cylinders.
40 lb cylinders soft covers
* This post was edited 11/13/20 04:14pm by mobeewan *
CavemanCharlie
Storden,MN
Posted: 11/14/20 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
And taillights. I always check them to make sure they work. If I didn't with my luck one would be out and the minute I pull out a cop would get behind me, notice one of the lights out, and give me a ticket.
capacitor
California
Posted: 11/14/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Is the hose from the trailer to the regulator long enough to flip the tanks with valves facing forward? Mine isn’t and neither of my sons are.
deltabravo
Spokane, WA
Posted: 11/16/20 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Mine face forward as shown here, when I put a lock on the tanks
I've never seen them face the other way in all my years of RVing.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
CavemanCharlie
Storden,MN
Posted: 11/17/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
3 of the 4 TT I've had have them faceing backwards. The 4th one only had one tank.
