RV.Net Open Roads Forum: Need help with a SF 30 Suburban Furnace
 > Need help with a SF 30 Suburban Furnace
mikestock
Vestavia Hills, AL, USA
Posted: 11/12/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a stack 3" thick but so far, I haven't been able to find the manual for the thermostat.
mikestock
Posted: 11/13/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Finally, through failing to find any other fault, ordered the replacement thermostat for $87. If I'm wrong, I remember, I'm spending my kid's money.
enblethen
Moses Lake, WA
Posted: 11/13/20 08:55am Link  |  Quote  |  Print  |  Notify Moderator
You are aware that there is thermostats that are direct replacements locally?
I switched out to a programmable LUX.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
mikestock
Posted: 11/13/20 09:32am Link  |  Quote  |  Print  |  Notify Moderator
I don't like to go into stores, right now and I already know that Camping World would be $110+. I hope I can replace wire for wire with the same thermostat. We'll see. My noisy heat pump still works if the temp stays above 40. Much below 40 I'll probably stay home.
enblethen
Moses Lake, WA
Posted: 11/13/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
This is the one I got on line.
Lux thermostat
mikestock
Posted: 11/14/20 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Lux thermostat
I can't see how to select between gas heat and and heat pump. I don't think this would work with my system.
enblethen
Moses Lake, WA
Posted: 11/14/20 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Here is LUX Manual
mikestock
Posted: 11/14/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
It still doesn't allow you to choose between gas heat and electric heat.
enblethen
Moses Lake, WA
Posted: 11/14/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
See page 20 of the manual
mikestock
Posted: 11/14/20 11:45am Link  |  Quote  |  Print  |  Notify Moderator
OK. It appears that a wiring change would be required. I assume this extra switch would go above or below the thermostat.
I ordered one just like the one I had. I need SIMPLE and I hope that's what I am getting.
