RV.Net Open Roads Forum: Roads and Routes: US 312 in Tn
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > US 312 in Tn
haste maker
alabama
Posted: 11/12/20 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
How is the drive from Lenoir City TN to Pigeon Forge TN on highway 321.
Retried Teamster
2007 Allergo
kohldad
Goose Creek, SC
Posted: 11/12/20 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
From Maryville to Townsend it is a wonderful dual lane road for the most part. Just before Townsend area there are about 2 - 3 miles that is single lane still with a few decent curves (35mph) but not that bad.
Coming out of Townsend, you enter a steep grade with multiple tightish curves. This is the worse section but doable if you don't mind typical single lane mountain roads. Once in Wear Valley it straightens back out for a few miles. Then it gets a bit curvey and hills again the last few miles into Pigeon Forge.
Haven't driven from Lenoir City to Maryville but should be a decent dual lane road the entire way.
If you want an alternative, suggest 321 to Maryville then 411 to 441 into Pigeon Forge. The worse section of this route will be 411 which is a pretty straight and flat single lane road. Everything else will be dual lane.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
bgum
South Louisiana
Posted: 11/12/20 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
We didn't like the part coming out of Townsend. Don't get a wheel off or you will be sorry.
ken56
Tennessee
Posted: 11/13/20 03:04am Link  |  Quote  |  Print  |  Notify Moderator
No issues until you reach the part others here have mentioned. Out of Townsend the is a hill with some turns. They have a good apron and are wide and do able. It's about 4 miles worth. The rest into PF is good. If you are pulling a trailer bigger than a POD UNDER NO CIRCUMSTANCES, DO NOT go into the park. 321 is a left turn to stay on it. Going straight will take you into the park. Little River Gorge road is a pretty drive just don't tow your trailer on it, it wont accommodate a large combo or motor home.
haste maker
alabama
Posted: 11/13/20 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I like the looks of that route...thanks
ken56
Tennessee
Posted: 11/13/20 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Just a heads up, 411 is a 2 lane road and some might say it's narrow. I would pull my 37 ft. trailer on it but some might be a bit uncomfortable. Tennessee is not known for having shoulders on their roads. Once you hit 441 its good wide 4 lane most of the way but no issues with it.
 > US 312 in Tn
