RV.Net Open Roads Forum: Tech Issues: Jacking up an RV
 > Jacking up an RV
time2roll
Posted: 11/13/20 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
Parking it at a seasonal site but needing it high enough for the honey wagon to get under the pipe.
OK I would tend to extend the pipe to be convenient.
Otherwise jack on the frame not the bumper.
675w Solar pictures back up
mobeewan
Hampton, Va
Posted: 11/13/20 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
I use a floor jack with a stack of 2x4s to get the height needed. Jack point is the frame close to the spring hanger. Then I set the frame on 12T jack stands.
To just change a single tire I use a small hydraulic to lift the axle direct just enough to get the tire half inch off the ground. I jack on the U-bold to avoid axle tube damage.
What work are you doing?
I did this to replace all 4 tires, 2 tires at a time, one side at a time. I think my jack stands were 3 ton each. Bottle jack is 9 ton placed just in front and just behind the spring shackles. Trailer gross weight loaded at the time was about 6000.
dryfly
Posted: 11/13/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
1999 Rockwood Ultralight
Plan is to jack it up, slide boars under the tires, and the lower the jack back down.
Sliding a boar under the tires is dangerous. They are mean and will try to bite you. Also, they will probably get away before you can lower the jacks back down.
Sorry..............couldn't resist.
swimmer_spe
Sudbury, Ontario, Canada
Posted: 11/13/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
You win!!!!
So, How else do you get a boar under an RV?
Wherever I happen to park
Posted: 11/14/20 03:43am Link  |  Quote  |  Print  |  Notify Moderator
Generally jacking at bumper not good idea on RV
My favorite position for jackinmg depends on if I wish to lift the tire off the ground but. Under the axle where the springs attach for tire lifting.
Where the springs attach to the frame for other lifting.
Home is where I park it.
Sjm9911
New Jersey
Posted: 11/14/20 07:37am Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
I cannot do ramps. There is a bar that hangs down to catch the curb at the back that would prevent me from using ramps. Those would catch the ramps.
you can pull forward on them also. Make like a step chock. Move peices as needed. Go up a few inches, move the blocks around to the front and add another board. Jacking will work also, but you will need a level surface and a good base for a bottle jack. And dont put your hands under the tires ,just incase!
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Veebyes
Posted: 11/14/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
So this will be a semi permanent raising?
Bottle jack under bottom spring leaf next to axle & lift as planned. Up, transfer weight back to wheel, re block, lift again, transfer etc. till you are at the height you want to be.
2007 Alpenlite 34RLR
swimmer_spe
Posted: 11/14/20 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it will be semi permanent.
That was what I was avoiding having to do, but it sounds like the best way to prevent damage.
JaxDad
Greater Toronto Area
Posted: 11/14/20 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
You win!!!!
A pile of carrots, parsnips or potatoes will bring them in on their own.
A .300 Winchester Magnum will keep them there.......
2oldman
south
Posted: 11/15/20 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
I could, but I'm glad you couldn't! [emoticon]
 > Jacking up an RV
