RV.Net Open Roads Forum: Tech Issues: Jacking up an RV
 > Jacking up an RV
swimmer_spe
Sudbury, Ontario, Canada
Posted: 11/12/20 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
1999 Rockwood Ultralight
I need to raise it up about a foot off the ground. Plan is to jack it up, slide boars under the tires, and the lower the jack back down.
Can i just jack on the bumper without bending it or the frame? I would jack where the frame meets the bumper.
How would you raise it up?
TenOC
On the road -- Full time
Posted: 11/12/20 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure to put the jack where the axles join the springs otherwise you run the risk of bending the frame.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
DrewE
Vermont
Posted: 11/12/20 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
The bumper on a trailer is rarely structural. As TenOC suggests, the surest way is to jack the axle where it mounts to the suspension, as that unquestionably is sturdy enough to support the trailer (or indeed any other vehicle). It may be simpler to get or assemble a set of ramps to drive/pull it onto rather than jacking the trailer.
time2roll
Posted: 11/12/20 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
I use a floor jack with a stack of 2x4s to get the height needed. Jack point is the frame close to the spring hanger. Then I set the frame on 12T jack stands.
To just change a single tire I use a small hydraulic to lift the axle direct just enough to get the tire half inch off the ground. I jack on the U-bold to avoid axle tube damage.
What work are you doing?
675w Solar pictures back up
rockylarson
Jersey Shore
Posted: 11/13/20 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Bumpers are mostly cosmetic. I have seen many pushed in, bent back, or almost torn off due to misuse.
More discussions here: Lifting 5th wheel RV
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
swimmer_spe
Posted: 11/13/20 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Parking it at a seasonal site but needing it high enough for the honey wagon to get under the pipe.
Sjm9911
New Jersey
Posted: 11/13/20 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Tbh, i would just make a ramp the correct height and pull or push the camper onto the blocks. 1 foot isnt a lot of height. After rasing it , you may need blocks for the stabilizers and toung also. Could you dig a hole for the honey wagon? If you didnt get one yet they sell low profile ones also.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
agesilaus
North Florida
Posted: 11/13/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Ditto on ramps, 12 inches is a long way using bottle jacks. Floor jacks require a hard surface to work from, like concrete.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
BarneyS
S.E. Lower Michigan
Posted: 11/13/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
swimmer_spe
Posted: 11/13/20 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot do ramps. There is a bar that hangs down to catch the curb at the back that would prevent me from using ramps. Those would catch the ramps.
 > Jacking up an RV
