RV.Net Open Roads Forum: Fifth-Wheels: Air bubble under front of rubber roof
 > Air bubble under front of rubber roof
mikestock
Vestavia Hills, AL, USA
Posted: 11/14/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I had one of these under the front of a fiver I owned. The roof had cone unglued for about 6', that I could tell. Never knew until I happened to walk up top to lub my tv antenna.
Looking for a repair I blocked it up for several days during dry, hot weather. I used an abundant amount of spray glue and covered the underside of the skin as best I could and used a heavy blanket and weights to hold it down for a day. There was no way to get the skin back in place under the aluminum strip that was supposed to hold it.
I bought a 1" X 3/8" aluminum bar from Lowes, drilled and countersunk holes about every 8". Cut it to length and installed it about 1/4" behind the original strip and filled the 1/4" gap, screw heads and joints with Dicor sealant.
This worked and stayed in place for the three more years I owned the fiver.
Hope this works for you or someone else that you wee driving down the road with the bubble.
phillyg
SWFL
Posted: 11/14/20 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info. I've seen a few RVs on the road with the bubble and it's likely they have no idea.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Lone Pine, CA
Posted: 11/14/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
“and it's likely they have no idea...” cuzz most RVers don’t do annual roof maintenance.
ford truck guy
Pennsylvania
Posted: 11/15/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
I've seen many RV rolling down the road with air bubbles....
When I buy a new trailer, the first thong I do is run a piece of 6" Eternabond across the seam. This prevents ( I believe ) the air from having any type pf chance of getting under the front seam...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Super_Dave
Harrisville, UT
Posted: 11/15/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
True or false, roof bubbles aren't a big deal?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
mikestock
Posted: 11/15/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Eventually if not immediately a very big deal.
ford truck guy
Pennsylvania
Posted: 11/15/20 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
DEPENDS....
They ( Alpha ) says that there will be "some" small bubbles in hot temperatures... Small, as in quarter sized bubbles...
mikestock
Posted: 11/17/20 06:28am Link  |  Quote  |  Print  |  Notify Moderator
I now have a 14 year old diesel pusher and a disturbing fact of life is, plastics break down, glues break down, wiring insulation breaks down, foam rubber will age, especially if heat is involved, rubber tires are unsafe after about 8 years and sun does it's job on rubber roofs and paint. You can buy a slightly used 10 year old rv and be sure that stuff is going to happen.
