RV.Net Open Roads Forum: Tech Issues: Generator Timer Click, click how to change
 > Generator Timer Click, click how to change
base1957
Posted: 11/14/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
The generator timer is loud constant click, click, when counting.
Looking for a digital one... is it 12 v or do i get 120?
Whats a good one?
thanks
bgum
South Louisiana
Posted: 11/15/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
It is my understanding that the timer runs by wrapping a single wire around your spark plug wire. That should give you a good idea of the voltage. Check YouTube for how it works.
KD4UPL
Swoope, VA
Posted: 11/15/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Considering no body know what generator we're talking about it's hard to make a good recommendation. However, it is almost assuredly not 120v.
Most Onan and other quality generators use a 12v meter. Many portable types wrap the spark plug wire as bgum mentions.
mchero
Henniker, NH
Posted: 11/15/20 07:50am Link  |  Quote  |  Print  |  Notify Moderator
What do you do about zero hours on your meter 'if" you do change to electronic? Can you add the needed hours to get it back to current?
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
bobsallyh
Livingston, TX.
Posted: 11/15/20 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I have an Onan Marque Gold 7000 with a remote hour meter in the fiver. Whether digital or old style it is powered by 12 volt off the genny while running. If you want to change to digital, hook it up the same way. If want to put hours on the new meter, simply hook it to a 12 volt supply and let it run until the hours show what you want before wiring it into the Onan.
mchero
Henniker, NH
Posted: 11/15/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Good point. Did not think about that!
base1957
Posted: 11/17/20 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry I did not identify the generator.... its a Onan Marquis 7000
Here is a pic of the counter thats currently in . Im looking for a digital replacement and as stated by someone earlier it should be a 12 v?
mchero
Henniker, NH
Posted: 11/18/20 12:03am Link  |  Quote  |  Print  |  Notify Moderator
Says right on the tag, 12 to 21 vdc correct?
base1957
Posted: 11/18/20 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Yes....got one coming..thanks
mchero
Henniker, NH
Posted: 11/18/20 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Keep us posted on your project. Let us know how you connected the leads.
