RV.Net Open Roads Forum: Tech Issues: Filling small holes in Filon/Fiberglass exterior walls
 > Filling small holes in Filon/Fiberglass exterior walls
Baja Man
Inland Empire, CA
Posted: 11/14/20 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a few 1/8" screw holes in right and left exterior walls (where previous baggage compartment door holders were screwed down). Couple of holes in wall and a couple in doors (each side).
What is the best / preferred way to fill in these holes? It's a 12 year old trailer so not too concerned about getting an exact color match.
NOTE: Filon in both wall and doors is thin and there is no backing.
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2009 Thor-MVP RV- Tahoe 284SA
BobsYourUncle
Calgary Alberta Canada
Posted: 11/14/20 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
The doorknob who had our TT before us hung a decoration on a wall with drywall screws that were longer than the wall was thick....
Screws were sticking out the wall on the outside.
When I pulled them out I just used some polymer based caulking a similar color and filled the holes, then smoothed it off on the outside and cleaned up any excess.
The thing to do is put the caulking tube nozzle right tight to the wall surface, then pump pressure on the gun for a second, then release the pressure before pulling the caulking gun away. This will force caulking right into the hole a ways so it isn't just on the surface.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Currently under construction, big project! Will change this when done.
Marcela
Kansas
Posted: 11/15/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Clear silicone sealant is your friend. And it will match perfectly the surrounding color.
TUCQUALA
Kennewick, WA
Posted: 11/15/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Seal holes, install stick on levels for front to back leveling. That's if the storage doors are at front of trailer!! 99% are!!
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
BarneyS
S.E. Lower Michigan
Posted: 11/15/20 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
pauldub
North of Seattle
Posted: 11/16/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Never use silicone. When in needs maintenance in the future, nothing will stick.
BobsYourUncle
Posted: 11/16/20 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed! And the silicone won't stick either. It will cause a leak around itself.
A good polymer based sealant is the best choice. It will even adhere to wet surfaces. I use Weathermaster Titebond in my solarium business. Best I have ever found for the application.
There are others, widely used here by members, but no to silicone.
Gjac
Milford, CT
Posted: 11/16/20 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
If it is white Filon I would use Marine-tex or any white epoxy sold at any marine supply store. Sounds like you are filling a few holes maybe 1/8 in in dia so you can even by a 3 oz tube of 3M 5200 to fill the holes. Just smooth it of with a putty knife after you fill the holes.
