RV.Net Open Roads Forum: Fifth-Wheels: Fifth Wheel Purchase
 > Fifth Wheel Purchase
BurbMan
Islip, Long Island
Posted: 11/16/20 10:34am Link  |  Quote  |  Print  |  Notify Moderator
SonnieP wrote:
The sticker on the door well is 1612lbs
Here are the 24RE specs:
Unloaded Vehicle Weight (lbs) 7980
Dry Hitch Weight (lbs) 1495
Gross Vehicle Weight Rating (lbs) 9995
Gross Combined Weight Rating (GCWR) 12995
Cargo Carrying Capacity (lbs) 2015
So 1612-1495 = 117 lbs available capacity after hitching the trailer.
Real world: Average folks add 1200 lbs of stuff to their RV, so the hitch weight is likely going to be in the 1800 lb range, add 200 lbs for the actual hitch, and 150 lbs each for driver and passenger, you are at 2300 lbs. 2300-1612 = 688 lbs overloaded on the truck.
We always wind up buying a bigger trailer than we think we will (also known as 2 foot-itis), and why the wise old guys here on the forum will tell you to but the trailer first then buy the right truck to pull it.
You should be able to find any number of TTs that have a comfortable floorplan like the 24RE with tongue weight well within the range of your truck. Get a good weight distributing (WD) hitch and it will tow just fine.
I would suggest buying a used trailer, see how you like it, when it's time to upgrade the truck in 2-3 years then you decide if you want to go 5er. A 5-ish year won't depreciate near as much as a new one in the next 3 years.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
SonnieP
Alabama
Posted: 11/16/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Probably should move this to the travel trailer forum now.
We were originally looking at travel trailers and my friend got us side-tracked on 5th wheels. IF we got back to considering a travel trailer. I am curious as to what we can safely pull with my truck.
I was mistaken on the payload... transposed the numbers. Sticker in door well shows 1612lbs.
1612lbs to start.
-400 - my wife and I
-100 - tool box with a few tools (I can pick it up easily)
-200 - other stuff in the truck (sub box, running boards, etc)
-150 - ? truck hitch weight
762lbs - is what the trailer hitch weight can be - am I calculating this correctly?
We will have some clothes in the trailer... no water... a couple of lounge chairs, hoses, cables, a few dishes, and some food. We'll add a Dishmate for our Dish satellite.
So if I am safely at about 600-700lbs hitch weight... how do I calculate what the weight of the trailer can be?
We definitely would not want to be over about 26ft for safety reasons.
Regards,
Sonnie
wing_zealot
East of the Mississippi
Posted: 11/16/20 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Tongue weight should ideally be 12% of the trailer weight (10% minimum). So 762 divided by 12% = 6350 lbs (trailer weight fully loaded and traveling down the road ready to camp). Clicky - Non-biased, reliable information
valhalla360
No paticular place.
Posted: 11/16/20 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Agreed, I would treat the 6350 as max GVWR on the trailer as a starting point for trailers to consider.
If you want to get a better idea, go down to your local truck stop loaded as if you were going to hook up the trailer and weigh the truck (put the family, full tank of gas and all the gear you would take in the truck). That will give you both overall weight and per axle weight, so no guessing how much payload you have remaining. It's easy, will cost $12-14.
PS: transposing the payload to 1600lb doesn't leave you a towing power house but makes it a lot more viable to pull a travel trailer in the 20-26ft range.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
JIMNLIN
Oklahoma
Posted: 11/16/20 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
SonnieP wrote:
Not that it matters for a 5th wheel, but I transposed the numbers on the payload. The sticker on the door well is 1612lbs... NOT 1162.
We started out looking at travel trailers and let my friend convince me to go the fifth wheel route. If we decided to go with a TT, what should I look for to safely tow? Tongue weight and overall weight?
Regards,
Sonnie
Your 1500 Ram can tow a 5th wheel trailer but it would be a small one. Those that say a 1/2 ton truck can't/shouldn't tow a 5th wheel trailer. They are not all the same size. GVWR can go up to 8600 gvwr but more importantly RAWR up to 6000 lbs depending on truck brands/year models.
You have the truck so like all truckers you need front and rear axle weights, after loading hitch/folks/junk, to know how much capacity you have to work with which I would bet is going to be close to that 1612 lb payload numbers.
I would stay under 8000 lbs max "gross" TT weight for a more relaxing operation on long day trips. The 5.7 Hemi at 395 hp/410 torque coupled with the 3.90 rear axle ratio sure won't have any issues pulling a 8k trailer.
You mention a 5.8 etorque engine. Is that a typo ??
SonnieP
Alabama
Posted: 11/16/20 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info... and yes... it's a 5.8L Hemi with the eTorque.
BurbMan
Islip, Long Island
Posted: 11/16/20 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Wing_zealot finished the equation, I would look at TTs in the 5500-lb dry weight range, which should put you right about your 25' target size.
Valhalla, OP says in the first post the truck has 3.90 gears, so the Hemi should pull that weight just fine.
Running a little over weight isn't the end of the world, but load the truck too heavy and long highway drives can get real tedious real fast.
Njmurvin
Simi Valley
Posted: 11/16/20 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
My fifth wheel is 12K lbs and it is everything my 2004.5 Ram 3500 (with 5.9 Cummins Diesel) could handle. I can't imagine trying to pull it with a 1500.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
camp-n-family
London, Ontario
Posted: 11/16/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Still a typo. There is no 5.8l hemi. It’s a 5.7l in the Ram 1500.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
SonnieP
Alabama
Posted: 11/16/20 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Yep... 5.7L V8 eTorque
Hey... I was only .1L off... that's not much. [emoticon]
