RV.Net Open Roads Forum: Class A Motorhomes: Jack Placement to Change my Tire
 > Jack Placement to Change my Tire
Branson N Tucson
Tn
Posted: 11/16/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Next time try using the motor home jacks. They should lift the MH up were you can remove the tire
Executive
Posted: 11/17/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind the rear tires are the easiest to change. You don't even need a jack if it's an outside dual. Simply drive onto a chock block with the inner wheel and remove the outer one. Put the new one on and drive away.
Be sure to recheck the torque on the lug nuts after a couple hundred miles....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
JRscooby
Indepmo
Posted: 11/17/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
This works well on old Budd wheels, if you re-torque the inner nuts before you put outside back on. But on hub-piloted, it's a good way to shear studs. Either when it shifts far enough, and weight is on the studs, or when just a little, and proper torque will not pull back in place. As soon as you roll, the lugs are loose.
Argosy24
MI
Posted: 11/19/20 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Agreed, you really don't want to pull the only set of lug nuts off while the vehicle weight is still on the inner tire. You could go from a minor problem to a major disaster, or be seriously injured.
