RV.Net Open Roads Forum: Truck Campers: Escape Hatch Condensation
 > Escape Hatch Condensation
BurbMan
Islip, Long Island
Posted: 11/16/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Our 2002 Lance 811 has the crank-up hatch over the bed that also has the quick-release as an escape hatch. With cool weather outside, the aluminum frame produces condensation like crazy, to the point where it drips on the bed.
The factory did provide an insulated vinyl cover that snaps to the ceiling around the hatch. The problem is it doesn't form an air tight seal to the ceiling, so condensation still forms and just puddles on the top of the vinyl cover.
Obviously what's needed is a way to stop the inside air from contacting the aluminum frame of the hatch. I thought about spraying some of that Flex Seal liquid rubber on the exposed aluminum but not sure if that would insulate it enough.
What have you guys figured out for this?
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
narcodog
Georgia
Posted: 11/16/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
What I did and it did not cure the condensation completely it did lessen it some what. I went to HD and bought a roll of the foil backed foam pipe insulation. I cut it to fit. Now it does eliminate light transmission but that doesn't bother me.Then I using the snap cover I put some insulation in the opening held up by the snap cover.
Kayteg1
California > Nevada
Posted: 11/16/20 09:02am Link  |  Quote  |  Print  |  Notify Moderator
cut a square of Styrofoam to fit tight into opening.
Better yet, you can buy polyurethane boards at HD with foil on both sides. Put some masking tapes on the edges to prevent scratching the foam.
* This post was edited 11/16/20 09:10am by Kayteg1 *
billtex
RI
Posted: 11/16/20 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Open the hatch a crack.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
stickdog
Somewhere, USA
Posted: 11/16/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Quit breathing.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Bishop area, California
Posted: 11/16/20 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Dog's recommendation is a last resort problem solver IMO.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
BurbMan
Islip, Long Island
Posted: 11/16/20 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
stickdog wrote:
Quit breathing.
Did my wife tell you to post this?
zulu52
Cypress, Texas
Posted: 11/16/20 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with this. Just 1/4" worked for me. No condensation.
Zulu
Bedlam
PNW
Posted: 11/16/20 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
X3
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
covered wagon
Posted: 11/18/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I used the foam padding that comes in a roll for under your sleeping bag when your sleeping on the ground. Easy to cut and flexible, you can cut it a bit large and stuff it tight. This has helped a lot. I lined the underside of the hatch cover as well using contact cement. Remember to cut a bit larger for snug fit.
If you don't do a good job remember the hungry Grit Dog will bite you right where it counts.
* This post was edited 11/18/20 09:20am by covered wagon *
