Jbird
Ive given up on finding the answer to a relatively simple question online or on the forum here. Hope somebody can help me:
What is the real ,actually using it, curb weight of a late model 1500 pickup? The factory brochures give GVWRs and payloads,but the latter is not at all helpful if one doesnt have some ballpark idea of curb weight. I find one F150 owner weighing in at 6600; one online site suggests any where from 4900 to 5300 for a GMC. That's quite a range!
36' Mobile Suites,Chev 3500 Duramax
MFL
Midwest
All curb wts will vary depending on how equipped. If you are looking at a particular truck, look at the GVWR, for example 7,500. Now look at payload on tire sticker 1,500. This means that curb wt of THAT truck was 6,000 as it left the factory.
Jerry
valhalla360
No paticular place.
Depends on the specific model and how it's outfitted. 1/2 ton is a very generic description in the modern truck market.
Huge difference between a stripped out 2WD V6 standard cab short bed and a 4WD V8 crew cab long bed with all the bells and whistles.
If you can see the door sticker, you can usually back calculate it based on the GVWR and payload but even there you have to be careful of dealer added items. A 200lb bed cap will likely not be included in the sticker for example.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
near Bishop, California
My Silverado weighed 5288 pounds when I picked it up.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
stickdog
Somewhere, USA
If your looking at new trucks ask the sales person to see the shipping ticket. That's the wt sans fuel other than the 2-3 gal shipped with and any dodads a dealer may have added.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
gmckenzie
BC
My 2015 has a GVWR of 7,600 lbs and a payload of 2015, so I assume the curb weight is the difference? But I'm never sure what they take into consideration for the payload numbers.
2015 GMC Sierra 4x4 CC SB Max Trailer
2010 Cougar 30RKS
JIMNLIN
Oklahoma
Quote: What is the real ,actually using it, curb weight of a late model 1500 pickup? The factory brochures give GVWRs and payloads,but the latter is not at all helpful if one doesnt have some ballpark idea of curb weight. I find one F150 owner weighing in at 6600; one online site suggests any where from 4900 to 5300 for a GMC. That's quite a range!
Actually 1/2 ton trucks gross weights across the brands will vary much more than that. Same with one tons or 3/4 ton trucks.
New trucks have a shipping weight as it leaves the factory which can be on the window sticker...sometimes.
If you need a weight to register a truck then use its GVWR or the sum of FAWR and RAWR.
If your trying to figure how much a track can safely carry then curb weight minus its GVWR numbers isn't always good/safe number to use for a newer pickup truck that carries its payload over the rear axle.
MFL
Midwest
gmckenzie wrote: My 2015 has a GVWR of 7,600 lbs and a payload of 2015, so I assume the curb weight is the difference? But I'm never sure what they take into consideration for the payload numbers.
You are correct on the curb wt as it left the factory. Just a thought... to show that axle wt ratings matter most.
F150 with HD payload pkg, with 2,400 lbs payload
F250 with diesel engine, only having 2,100 payload
Which truck can carry the heaviest load???
Well of course the 250, due to having waaayyy more axle/tire capacity!
Many 1/2 tons run out of axle capability, about the same time as payload rating is reached. In some cases sooner.
Jerry
Boomerweps
Hills of PA
Known values.
Full tank of gas
Some include 150# driver.
Weight of vehicle when it left the factory.
Subtract the above from GVWR.
Remainder is factory Load capacity or payload.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
wing_zealot
East of the Mississippi
Clicky
