RV.Net Open Roads Forum: will a flat tire cause my fifth wheel to lean
 > will a flat tire cause my fifth wheel to lean
tikki23
morgantown
Posted: 11/16/20 09:10pm Link  |  Print  |  Notify Moderator
I've noticed after a few month my fifth wheel.started to lean an i looked outside an two tires are flat on that side could that cause it?
Flute Man
Payson, Arizona
Posted: 11/16/20 09:32pm Link  |  Print  |  Notify Moderator
Yes, it sure could.
Pump them up and then you will know for sure.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
time2roll
Posted: 11/16/20 10:55pm Link  |  Print  |  Notify Moderator
That or your driveway has developed a tilt.
675w Solar pictures back up
dryfly
Posted: 11/16/20 11:11pm Link  |  Print  |  Notify Moderator
Very common with newer 5th wheels. Most economical and effective solution is to let the air out of the two tires on the other side of the trailer. Lots of YouTube videos on this subject.
cavie
Posted: 11/17/20 03:49am Link  |  Print  |  Notify Moderator
Is this a trick question?
bucky
Raleigh metro
Posted: 11/17/20 04:11am Link  |  Print  |  Notify Moderator
Looking at the join date this is just another in a long string of such things.
The best PDI in the world is worthless in the face of the RVing buying onslaught.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Tyler0215
Iowa
Posted: 11/17/20 04:53am Link  |  Print  |  Notify Moderator
How could two flat tires on the same side cause a tilt?
LOAD THE PARTS CANNON! New springs, shackles, shocks. But don't air up those tires.
BurbMan
Islip, Long Island
Posted: 11/17/20 05:39am Link  |  Print  |  Notify Moderator
I don't know, is it? Or does it just look like a trick question to trick you?
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
ford truck guy
Pennsylvania
Posted: 11/17/20 05:40am Link  |  Print  |  Notify Moderator
Weak springs will cause a lean.... Weak springs happen.... BUT... 2 flat tires on the same side would cause a BIG LEAN ! ! !
Figure that the side with 2 flats will be close to 5-6" lower than the other side... Have you NEVER had a flat on any vehicle before to notice?
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Lynnmor
Red Lion
Posted: 11/17/20 06:07am Link  |  Print  |  Notify Moderator
Don't they put air in at the factory? [emoticon]
