RV.Net Open Roads Forum: will a flat tire cause my fifth wheel to lean
 > will a flat tire cause my fifth wheel to lean
agesilaus
North Florida
Posted: 11/17/20 08:59am Link  |  Print  |  Notify Moderator
Lynnmor wrote:
Don't they put air in at the factory? [emoticon]
That's an extra charge add on
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
BarneyS
S.E. Lower Michigan
Posted: 11/17/20 09:48am Link  |  Print  |  Notify Moderator
I think the factory ran out of air to fill them when they made your rig.
Barney
Not towing now.
MFL
Midwest
Posted: 11/17/20 10:14am Link  |  Print  |  Notify Moderator
way2roll wrote:
New member, first post, a word salad of grammatical errors and the question is - if 2 flat tires will cause a FW to lean??? If this isn't a troll post I don't know what is.
Agree, but any entertainment in desperate times, when people need to smile, helps. The FW forum has been extremely slow lately! It is okay to feed the troll. [emoticon]
Jerry
Old-Biscuit
Verde Valley
Posted: 11/17/20 10:19am Link  |  Print  |  Notify Moderator
Let the air out of the other side 2 tires and FW will then be level/no tilt
Simple........
US NAVY------USS Decatur DDG31
tikki23
morgantown
Posted: 11/17/20 10:28am Link  |  Print  |  Notify Moderator
Well pumping up the tires didn't work so is there anyway to level my fifth wheel without a truck?
tikki23
morgantown
Posted: 11/17/20 10:30am Link  |  Print  |  Notify Moderator
And no. No trolling here. Just kinda new to all of this.
time2roll
Posted: 11/17/20 10:52am Link  |  Print  |  Notify Moderator
Side to side use leveling blocks under the tires. Some use wood planks.
Front to rear, the front jacks need to be moved up or down.
675w Solar pictures back up
way2roll
Wilmington NC
Posted: 11/17/20 11:09am Link  |  Print  |  Notify Moderator
Well maybe some more context to your question could have yielded better answers. What year make and model of FW? Is this FW new to you or have you had it a while and this is a recent problem? Does it have leveling jacks? If it has jacks, are they electric or hydraulic? Are you parked off camber? Why are the tires flat? Flat tires certainly could be the root cause of why it started to lean in the first place.
If you don't have leveling jacks then getting the inflated tires up on leveling blocks could help but you will need a truck with a FW hitch to accomplish this - or a jack strong enough to lift it to get blocks/boards under.
We get a few trolls on this site and this had all the red flags. Nothing personal - word your questions with less ambiguity for better responses.
Williams AZ area
Posted: 11/17/20 12:41pm Link  |  Print  |  Notify Moderator
Concern - Flat tires on one side of a 5th wheel cause the 5th wheel to lean toward that side. Interesting.
Solution - Pump up flat tires and 5th wheel returns to level position. Insightful.
Concern - Parking spot isn't level. Good eye.
Solution - Move the 5th wheel somewhere else or use blocks under wheels on one side. Inventive.
dedmiston
The West
Posted: 11/17/20 01:34pm Link  |  Print  |  Notify Moderator
Fixing those two tires should be your first objective. You can't level your trailer when two of the tires are flat.
Once they're fixed, then you can use leveling blocks under the low side to raise it up.
Blocks under the tires are how you level from side to side. Your landing gear jacks level you from front to back.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
