RV.Net Open Roads Forum: will a flat tire cause my fifth wheel to lean
 > will a flat tire cause my fifth wheel to lean
Puddles
Lafayette, Indiana
Posted: 11/17/20 01:48pm Link  |  Print  |  Notify Moderator
I agree with... take the tires off and reinstall with the flat sides up. Should level that puppy right out.
HTML
time2roll
Posted: 11/17/20 01:55pm Link  |  Print  |  Notify Moderator
campingworld.com/jacks-leveling-chocks/levels-leveling-systems
675w Solar pictures back up
BarneyS
S.E. Lower Michigan
Posted: 11/17/20 04:56pm Link  |  Print  |  Notify Moderator
dedmiston wrote:
Fixing those two tires should be your first objective. You can't level your trailer when two of the tires are flat.
Once they're fixed, then you can use leveling blocks under the low side to raise it up.
Blocks under the tires are how you level from side to side. Your landing gear jacks level you from front to back.
Here is your answer. Thread closed.
Barney
Not towing now.
